Home > Maintenance & Mods (L322) > 2012 TDV8 battery drain - I've narrowed it down but... |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1194 |
It depends how many times you need to adjust the seat, you could leave it in one position and not connect it up. 2017 SDV8 4.4 silicon silver AB
23rd Jan 2023 3:23pm |
That's good news, well done with your persistence.
23rd Jan 2023 5:59pm |
KristoffL322 Member Since: 20 Jun 2022 Location: North West Posts: 27 |
The single led in the brake light is still there, but its super super dim. Can't even see it in day light. I think there must be a ground issue the high level LED light unit itself. It's so low that my meter can't resolve it, I tried it on the light fitting contacts and it's telling me its off. I am going to order a replacement as its a cheap part, but I think its unrelated to my recent problem.
23rd Jan 2023 6:08pm |
The alternator output voltage is fine, a combination of low temperature and partially discharged battery will be responsible. It's a managed charge system so the system voltage can range from 12.6 to (battery type coding dependent) around 15VDC. There's lots of information in the relevant 'description & operation' section of the workshop manual along with a graph of the charge voltage range vs. alternator duty cycle in the test & diagnosis section.
23rd Jan 2023 6:51pm |
Excellent, thanks for you help with my issue too, helped me stay focused and keep on trying to track it down rather than just give up (which at times I felt like doing). |
23rd Jan 2023 6:55pm |
