Home > Maintenance & Mods (L322) > Air compressor |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3112 |
You need to know the codes that are being stored to know why the suspension is inactive.
20th Jan 2023 5:22pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1194 |
dhallworth's post seems to be spot on, ( As usual )all I can add is that 'IF' the compressor efficiency has reduced, possibly due to wear, some of these compressors can be overhauled with a new piston ring kit etc, if required, this could save you a lot of money, especially if you do the job yourself. |
20th Jan 2023 5:48pm |
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 451 |
Spoke with my mechanic, it’s intermittently producing the code for failure to build pressure, so you were spot on.
20th Jan 2023 6:15pm |
Not sure which compressor is fitted to your car, as mine is a 2006, but here are some links to possible overhaul kits, by chance I had just been looking at buying a kit to store in the garage for when the weather is better, as mine is original and it is now 17 years old.
20th Jan 2023 7:13pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
20th Jan 2023 8:12pm |
