Home > Range Rover P38 > Bordeaux |
Huttopia Member Since: 26 Jun 2017 Location: Worcestershire Posts: 186 |
The nearest resort was Les Carroz, we were in La Frasse a few miles away. |
22nd Feb 2022 4:26pm |
Just had a small service and a new steering damper fitted, noticeable improvement. It is the only spend since the last service.
5th Dec 2022 9:51pm |
Happy Christmas and all that.....the passenger door won't open. I need a nimble fingered vandal to break the latch.. It also means I've got to use the D5 for shooting over Christmas. . |
15th Dec 2022 3:49pm |
I had a spare door latch in stock and Dave at 4x4 Development had the requisite knowledge and brute force to get the old one out. The door had superlocked which was handy....
10th Jan 2023 10:23am |
Nothing like a quick fix. Dave at 4x4 Development is in demand, so it has taken an age to get it booked in for the ball joint and rear exhaust. It does appear to have 4.6 axles and 4 pin diff, so that's a plus. Once these jobs are done it can have an MoT and then go for the windscreen to be re-bonded.
30th Mar 2023 10:11am |
She passed the MoT on Thursday (advisories were indicator bulbs not being orange enough and an oil leak). I had a crawl around underneath and there was no sign of the oil leak, so after quite a few months stood idle it was great to take the P38 down to Pembrokeshire at the weekend, along the back roads via Leominster, Brecon and Llandeilo. |
11th Apr 2023 4:03pm |
A few niggles to address.....
12th Jun 2023 11:11am |
Well.....patience and ££ are a virtue, even if in short supply at times.
11th Jul 2023 9:38am |
Just had the windscreen removed and refitted. The bond had failed. The guy doing it said he was surprised it hadn't fallen out.....which would account for the water ingress. Anyway, £140 all done.
25th Sep 2023 1:58pm |
At the weekend I managed to get 425 miles from a tank, which felt like a win, although still only about 20mpg….the vacuum based cruise control isn’t as efficient as a right foot, but better than no cruise. |
2nd Oct 2023 7:36am |
She's being parked up for a while having chewed through 2.5l of coolant. I've not worked out where the coolant is going yet and haven't got the time right now so I'm going to stick her in a barn and get another something to run around in, probably a D4. |
5th Dec 2023 8:56am |
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 297 |
What a fantastic colour match. Could I ask what the colour is called? I need to do mine. 2011 Range Rover Vogue 4.4 TDV8 2003 VW Golf V6 4motion 2001 Range Rover Vogue 4.6 1982 Range Rover in VOGUE 1990 Range Rover Vogue SE 2007 Audi A6 Avant Le Mans Quattro S-Line 3.0 TDI 2007 Skoda Ovtavia 2.0 TDI L&K 2007 GSX-R 750 K7 |
5th Dec 2023 9:30am |
Sure, the code on the can is 7350. I went to a paint shop in Redditch who came out with a few cards and mixed it up. I'm pretty happy with it. Obviously tempered with a potentially terminal coolant issue. I think Turner will be about £6k to rebuild and line the engine if the block is cracked.......just waiting for confirmation now.
6th Dec 2023 3:41pm |
Hi Huttopia,
7th Jan 2024 3:24pm |
