![]() | Home > Range Rover P38 > Bordeaux |
Huttopia Member Since: 26 Jun 2017 Location: Worcestershire Posts: 187 ![]() ![]() |
Dave Hodgett's entered the EKA via the diagnostic software and hey presto all good. I'm a bit wary about locking her up again, but it was good to hear her burst into life again! She will go back next week to have the central locking gremlins fixed and a few other niggles sorted out. |
It took me a while longer than planned to get her back to 4x4 Development and happily in the interim she didn't misbehave. She is still with Dave and he has been trying to get to the bottom of the random locking / unlocking. He's stripped and cleaned all of the plugs which were quite corroded, and he thought that had fixed it but then just this afternoon she decided to lock up. Most annoying! He's also sorting the cruise control which needs replacement pipes for the vacuum system. LR no longer supply them, but its pretty common hose so Ebay to the rescue. I also sourced a brass t-piece to replace the rather fragile plastic one.
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 301 ![]() ![]() ![]() |
I would argue Land Rover are certainly wrong. P38 is single din not double. For sure. RE the negative earth thing, I have no idea about that though but the genuine P38 stereos both Clarion and HK are single din. ![]() 2003 VW Golf V6 4motion 2001 Range Rover Vogue 4.6 1982 Range Rover in VOGUE 1990 Range Rover Vogue SE 2007 Audi A6 Avant Le Mans Quattro S-Line 3.0 TDI 2007 Skoda Ovtavia 2.0 TDI L&K 2007 GSX-R 750 K7 |
They actually came back to me re the stereo to confirm it is single DIN, so we aren’t going mad. They still state that a P38 can’t take the infotainment system because the surround is too wide and they aren’t prepared to make one to match. That isn’t a great surprise as I imagine there isn’t much demand, but I’d have thought someone with a 3D printer and a bit of an idea could crack it.
Happy days! There are posts on t'interweb where people have fitted a tablet in place of the sat nav screen and built their own so to speak. Some of them look pretty impressive. 2011 Range Rover Vogue 4.4 TDV8
Thought I’d stretch her legs this weekend so ditched the normal family wagon and took the P38 down to Pembrokeshire, about 130 miles via Presteigne, Builth Wells and Llandovery. Mrs H and the kids prefer it as there is more space and the seats are comfier for kipping!
DavidL Member Since: 14 Nov 2013 Location: wiltshire Posts: 141 ![]() ![]() |
If you wanted a nav system you could look at the Becker single din that came in freelanders. Look the part , have a LR splash screen and are good quality too. £100 or so on eBay, model 4765. |
Thanks David, they look good value. I’m not sure if the wiring in the P38 will support that unit- any ideas?
I have one in my Classic; now I'm aware the rear sub and amp aren't working through it but the HU has a reasonable amp.
MOT passed with no advisories at exactly 61,000m. Happy days. I'm now trying to sort the dampers for the glove box and the cubby box, both are shot and I have replacements, but helpfully the originals are riveted in, so a little awkward to remove. Getting there. |
The gear selector switch is playing up, if the vehicle doesn’t think it is in P it won’t start. It was a bit sticky previously. A new switch is £300 ish, an eBay used part is £40. Another job for the list... |
Ball joints done on the drivers side front wheel- but the ABS sensor isn’t happy so the dash is beeping about ABS and Traction failure....she drives fine but it’s annoying. Back to the garage Wednesday for a fix. My guess / hope is the sensor isn’t home. Anyone experienced similar in the dim and distant? |
The garage fitted a non Wabco sensor, which isn't sending back a meesage, hence the error. I'm now looking for a Wabco sensor for sensible money.... |
So the P38 is in for a bit of tlc. The wheel sensor has been replaced but the fault is still showing. It may be the Wabco ABS ECU. The ride is a bit unsettled so the front ball joints need doing. There is a very new leak into the drivers footwell, I suspect the windscreen surround. Oh and she needs a service.
