Home > My Range Rover > Finally, A Full Fat.
Page 2 of 5 <12345>
DrRob
Get Bodsy to do transfer and both diffs whilst he’s underneath.
Have PAS fluid change do out Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #651708 27th Dec 2022 9:48am
mgrover
Gonna do diffs and transfer myself.
I noticed the coolant tank is stained with oil. Now am assuming that means the oil cooler leak is sorted?
Am in Leeds, can anyone recommend a decent indie here?
I've noticed the round is a bit bouncy so gotta wonder are the shocks shot. But tbf so far so good. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #651746 27th Dec 2022 7:41pm
mgrover
Only had this car a month max and am already spending like a mad man Laughing
Full service kit, with oils for power steering/diff/transfer 350,
Fresh Coolant and distilled water, 44
Top coolant hose 113
Compressor rebuild kit 85
Set of new wheel nuts because the old ones are wrecked with new locking nuts, 100quid
Then new struts front and back
A new expansion tank because old one is filthy(mighta been handy to do this before the coolant flush but ah well will try to save the fluid Laughing)
Ofc there will also be the gearbox flush at another 350. Its actually a sport Sad
Post #652488 4th Jan 2023 9:59am
Weegie
Site sponsor Green Oval.? I’m not in Leeds but I did buy my car from them a few years agoand was impressed.
https://www.greenovalgarage.co.uk/ John
GAP iiD BT
Post #652490 4th Jan 2023 10:08am
mgrover
hmm fair enough ive been before so defo worth getting them to have a gander. Its actually a sport Sad
Post #652491 4th Jan 2023 10:15am
Giffer2018
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
You could also try Adventure Service and Repair based in Batley -----------------------
RR Vogue 4.4 TDV8 2011 - Galway Green
Kia Sorento 2.5 CDi 2007 - Bright Silver
Post #652518 4th Jan 2023 5:02pm
mgrover
Cross articulation fault today.
But my compressor is having trouble venting, got a rebuild kit on way. Hopefully I won't be chasing my tail with it Its actually a sport Sad
Post #652567 4th Jan 2023 9:35pm
Giffer2018
If suspension is not lowering/raising as it should, try removing the brown/gold colour vent filter on the compressor. These block up over time, if suspension works ok without it drill a hole in the centre of it. There are various posts on here regarding fixes for suspension problems. -----------------------
Post #652626 5th Jan 2023 12:46pm
mgrover
rebuilt the compressor, its now lowering as it should. but i think ive got a leak in the front left bag. fairly severe since it drops within like 30mins.
might bite the built and just swap both shocks as they are getting to that age.
the compressor was all gunked up so now it should be breathing more freely. Its actually a sport Sad
Post #652665 5th Jan 2023 6:10pm
mgrover
Hmm ordered the front air bags not full struts.
At 170k mileage should I just bite the bullet and do full struts? It's 250quid vs 1k
I can literally hear the leak from the front bag, I'll take a look tomorrow and hope it's the voss fitting loose or something Its actually a sport Sad
Post #652700 5th Jan 2023 9:46pm
Phoenix
Talk to Duckworths, a pair of BWI front struts with airbags is circa £600 for my 3.6 yours might not be that much more.
Post #652703 5th Jan 2023 9:58pm
mgrover
Hmm is that with active dampening?
Thats what really does it in
If I could have got the front dampers alone and upgraded later I would have but aerosus only sell those together Its actually a sport Sad
Post #652706 5th Jan 2023 10:04pm
DrRob
JAS Land Rover nr York is where I'd take it. Joe Hodgson is a legend. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #652727 6th Jan 2023 8:05am
mgrover
Just did the bonnet cable.
I think for the face lift ones you only need the cable and not entire mechanism because its a pita trying to use the new grommet.
I just pushed the new one back and used the existing one.
Attached a strong nylon wire/string to the old cable when you pull it back out towards footwell and then just pull it back
Don't use weak butchers twine or anything because it will snap 😂 Its actually a sport Sad
Post #652846 7th Jan 2023 12:19pm
mgrover
Just had a fight with the wheel nuts.
Clearly overtorqued and Censored in the past.
I need to take the wheels off properly and clean the threads but for now it'll do.
Is there any other maintenance to keep these from seizing or was someone just being a Censored with the air gun?
Am guessing reasonable amount of copper grease and torquing only to 140nm will see me set?
Anyone that has theres rounded, I managed to get the cap off and get a 19mm on there.
The procedure did claim the life of 4 sockets, but they are thankfully Halfords advanced so straight swap there. Its actually a sport Sad
Post #653380 12th Jan 2023 5:34pm
Page 2 of 5 <12345>
