![]() | Home > My Range Rover > Finally, A Full Fat. |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1293 ![]() ![]() |
The threads should be dry at 140nm if you put on grease etc you will over torque them
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
Ooo might try the ACF50, hopefully keeps these nice and "new"
hmm tbf torquing to 140nm and probably plenty of room to overtorque given how tight they were before. I mean I literally had to deadlift the breaker bar with both hands for some of them. i sprayed with WD40 for now. tbf just leaving at 140nm will probably be enough. Its actually a sport ![]() Not anymore, 4.4 TDV8 now ![]() |
+1 ![]() There is a lot of force going through these studs with these big wheels (some other 4x4's have 6 studs). If you grease them they will not be secure and the torque needed to secure them with grease with stretch the studs. If you are worried about them seizing just go round them every so often loosening and retorquing them. Infact you should be doing this anyway on any car. 2012 TDV8 Vogue (L322) |
tbf ive never had this problem with any other car.
Were they tight due to over tightening or due to corrosion? 2012 TDV8 Vogue (L322) |
I'd say both.
Breakaway torque is higher than tightening torque, there is a calculation based upon many factors, I'd guess it's north of 180Nm for Landrover wheel nuts.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1631 ![]() ![]() ![]() |
@Pheonix:
Thanks, some manufacturers (Audi for one) do specify a lubricant for the wheel studs (or bolts, I forget which they have), it's not any old grease or oil though, and the torque is a bit lower than other VWG vehicles that use the same parts for the hubs & nuts/bolts.
Well I guess when I've got wheels off I'll give em a good clean and torque em right and probably acf50 the wheel nuts to avoid swelling.
If your worried about corrosion on the threads, it might be OK to use a low-strength Loctite type product as a barrier, however this would need to be researched carefully: in its liquid state I suppose its still acting as a lubricant, however poor.
Tbf this car was next to the seaside before. Now its in the heartland of Leeds. So unsure if rust will be hte same type of problem here? Its actually a sport |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35542 ![]() ![]() |
will that panel you're selling not fit in your FF...obviously a bit of fettling will be required.. ... - .- -.
Am guessing it will as a double din. But it won't look as nice as the icebox version. It worked in the RRS because am guessing it was central
