Home > Maintenance & Mods (L322) > Slow recoiling seat belts
Danwilderspin
Hi all three of my seatbelt have decided to recoil really slowly and never fully recoil resulting in doors not shutting etc - is there a fix to this? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #652261 1st Jan 2023 5:29pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Two things, firstly behind the pillar trim panel there’s a metal bar screwed to the body that the belt slides behind, this gets gunged up with fluff etc. Secondly, fully extend the belt and thoroughly clean with a solution of warm water and a hand wash washing powder, then allow to fully dry out whilst still fully extended - best left until the warmer weather returns.
Post #652262 1st Jan 2023 5:34pm
dingg1
Spray with silicon lubricant.... It'll be like a rat up a drainpipe
Post #652265 1st Jan 2023 5:50pm
Phoenix
Take them out, wash them in a bucket of warm water & washing powder, sometimes it takes a couple of buckets, rinse in warm water then let dry naturally - not on a radiator. Obviously don't put the retractor in the bucket, use one of the food bag closers to stop the belt flying back in.
Works every time, spraying with anything is just pushing more contaminants in. The problem is that the belts get so dirty they can no longer bend enough to do the 180deg. turn at the top, wash all the muck out and they're flexible again.
Post #652267 1st Jan 2023 5:57pm
Fox889
Wet dishcloth with warm water, run it up & down to remove any mange that maybe on the belts, thoroughly dry then spray Mr Sheen on both sides of the belt, it’ll then give you a blister as it rockets back into its housing😂😂 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #652302 2nd Jan 2023 8:54am
