Home > Technical (L322) > Information button on indicator stalk
Page 1 of 3 123>
filthyliam
Hi all. I’ve done some digging and can’t see an exact response to this. The information button on the left hand column stalk has “frozen” on range and won’t cycle through trip etc. (everything else works on the stalk) I’ve noticed there are trip functions in the electronic dash menu, by resetting these using the steering wheel button would this release the stalk button or am I clutching at straws ? Thanks in advance for help
Post #651580 24th Dec 2022 12:23am
Phoenix
I had this, the display would behave 'oddly' and no amount of button pushing would change the display once running, a battery disconnect/reconnect resolved it for a while but the real fix was a replacement starter battery.
Of course, it's equally possible it's something else entirely, do you have diagnostics which can display live values from body systems?
Post #651583 24th Dec 2022 7:13am
you program what you what to see in the 'stalk' menu by pressing in for around 5 secs and a choice menu shoild come up on the nav screen....you then select or deselect the options. ... - .- -.
Post #651585 24th Dec 2022 8:10am
DrRob
I never knew that Stan! Cool. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #651593 24th Dec 2022 12:34pm
GraemeS
Maybe a L405 feature as mine just resets the trip meter.
Post #651609 24th Dec 2022 8:00pm
filthyliam
I think this maybe a stalk issue, I’ve held the silver button in and nothing happens. The display won’t move off range. I have also gone into the main menu via the right hand steering wheel buttons and down to trip 1 and 2 then reset then it prompts you to hold the silver information button in which I’ve done but still nothing. Had a look on eBay for second hand stalks and some look to be a pair ( need to change both) is this correct ?
Post #651611 24th Dec 2022 8:12pm
Weegie
IIRC they are individual. It is a while since I did it but had them off when I fitted shift paddles. As I recall they slot into either side of a ring which is located behind the wheel.
It may be a wiring issue with yours - chaffing or the like. It’s straightforward to remove the wheel to get to them. Just a bit of a fiddle releasing the wheel. If you do it just be careful to disconnect all the connector behind the airbag. I missed the heated wheel connector and ended up with a replacement clock spring. 😃😟 John
GAP iiD BT
Post #651614 24th Dec 2022 9:00pm
mjdronfield
The programming what you see by holding the stalk in came from BMW. My 1988 7 series had that feature.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #651616 24th Dec 2022 9:11pm
GraemeS
Does your L322 have it?
Post #651621 24th Dec 2022 11:29pm
filthyliam
Ok thank I don’t have software or this level of skill so will
Be one for the garage I think. Thanks for all your help
Post #651622 24th Dec 2022 11:43pm
mjdronfield
My 2003 had it. Think my 2011 does, but as it has about 15 Trip and MPG functions now 🤣 none of which I know how to reset, I don’t use it anymore, which is a bit unlike me to take the time to try things but it’s just on date and mileage now.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #651628 25th Dec 2022 9:49am
GraemeS
I'll try it again while the display is on a non-trip display.
Edit: tried mine when blank and when date/mileage showing but no change.
It had been quite along time since BMW owned LR so presumably deleted with Ford upgrades.
Post #651631 25th Dec 2022 10:30am
filthyliam
Well whatever I’ve done on the main dash display with the steering wheel buttons I’ve managed to get it onto “trip a” and can’t change back to range now !
Post #651637 25th Dec 2022 8:59pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #651639 25th Dec 2022 9:45pm
mjdronfield
And there might be something on 5 here that could assist. Not sure what’s in there.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #651640 25th Dec 2022 9:48pm
Page 1 of 3 123>
