Home > Technical (L322) > Information button on indicator stalk |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
I had this, the display would behave 'oddly' and no amount of button pushing would change the display once running, a battery disconnect/reconnect resolved it for a while but the real fix was a replacement starter battery.
24th Dec 2022 7:13am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
you program what you what to see in the 'stalk' menu by pressing in for around 5 secs and a choice menu shoild come up on the nav screen....you then select or deselect the options. ... - .- -.
24th Dec 2022 8:10am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
I never knew that Stan! Cool. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
24th Dec 2022 12:34pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2497 |
Maybe a L405 feature as mine just resets the trip meter. |
24th Dec 2022 8:00pm |
filthyliam Member Since: 01 Aug 2011 Location: Lincolnshire Posts: 81 |
I think this maybe a stalk issue, I’ve held the silver button in and nothing happens. The display won’t move off range. I have also gone into the main menu via the right hand steering wheel buttons and down to trip 1 and 2 then reset then it prompts you to hold the silver information button in which I’ve done but still nothing. Had a look on eBay for second hand stalks and some look to be a pair ( need to change both) is this correct ? |
24th Dec 2022 8:12pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
IIRC they are individual. It is a while since I did it but had them off when I fitted shift paddles. As I recall they slot into either side of a ring which is located behind the wheel.
24th Dec 2022 9:00pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
The programming what you see by holding the stalk in came from BMW. My 1988 7 series had that feature.
24th Dec 2022 9:11pm |
Does your L322 have it? |
24th Dec 2022 11:29pm |
Ok thank I don’t have software or this level of skill so will
24th Dec 2022 11:43pm |
My 2003 had it. Think my 2011 does, but as it has about 15 Trip and MPG functions now 🤣 none of which I know how to reset, I don’t use it anymore, which is a bit unlike me to take the time to try things but it’s just on date and mileage now.
25th Dec 2022 9:49am |
I'll try it again while the display is on a non-trip display.
25th Dec 2022 10:30am |
Well whatever I’ve done on the main dash display with the steering wheel buttons I’ve managed to get it onto “trip a” and can’t change back to range now ! |
25th Dec 2022 8:59pm |
25th Dec 2022 9:45pm |
And there might be something on 5 here that could assist. Not sure what’s in there.
25th Dec 2022 9:48pm |
