![]() | Home > Technical (L322) > Information button on indicator stalk |
I had this, the display would behave 'oddly' and no amount of button pushing would change the display once running, a battery disconnect/reconnect resolved it for a while but the real fix was a replacement starter battery.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35629 ![]() ![]() |
you program what you what to see in the 'stalk' menu by pressing in for around 5 secs and a choice menu shoild come up on the nav screen....you then select or deselect the options. ... - .- -.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
I never knew that Stan! Cool. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
Maybe a L405 feature as mine just resets the trip meter. |
filthyliam Member Since: 01 Aug 2011 Location: Lincolnshire Posts: 81 ![]() ![]() |
I think this maybe a stalk issue, I’ve held the silver button in and nothing happens. The display won’t move off range. I have also gone into the main menu via the right hand steering wheel buttons and down to trip 1 and 2 then reset then it prompts you to hold the silver information button in which I’ve done but still nothing. Had a look on eBay for second hand stalks and some look to be a pair ( need to change both) is this correct ? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
IIRC they are individual. It is a while since I did it but had them off when I fitted shift paddles. As I recall they slot into either side of a ring which is located behind the wheel.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
The programming what you see by holding the stalk in came from BMW. My 1988 7 series had that feature.
Does your L322 have it? |
Ok thank I don’t have software or this level of skill so will
My 2003 had it. Think my 2011 does, but as it has about 15 Trip and MPG functions now 🤣 none of which I know how to reset, I don’t use it anymore, which is a bit unlike me to take the time to try things but it’s just on date and mileage now.
I'll try it again while the display is on a non-trip display.
Well whatever I’ve done on the main dash display with the steering wheel buttons I’ve managed to get it onto “trip a” and can’t change back to range now ! |
Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
And there might be something on 5 here that could assist. Not sure what’s in there.
