Home > Maintenance & Mods (L405) > Getting ready for an oil change
Page 3 of 3 <123
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Oil change done. I will post a couple of photos later. I extracted 10l if the marking are to be believed.
I have added 9l and have checked the level. One mark below the top. So I am thinking of adding the other 400ml now. Then go for a drive.
But first a cup of tea. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #651365 21st Dec 2022 1:16pm
Gremlin500
@Luxmoggy:
10L? Shocked
That’ll be 9.5L oil and 0.5L Diesel! Rolling with laughter Rolling with laughter Rolling with laughter
Looking forward to your write-up before I have to join all you suckers! Rolling with laughter
(See what I did there? Embarassed ) Mr. Green “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #651367 21st Dec 2022 1:49pm
Kot
Well done, another cherry popped Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #651374 21st Dec 2022 3:12pm
luxmoggy
One issue was getting the top off the pipe to suck the oil out. I didn't want to come off. I think I will buy a new one. It rotated off the bayonet fitting to come up about 1 cm, then would twist with pliers but not pull off. This was the longest part of the whole process.
My €12 solution to level the car:
The extractor is connected to the car, next time I will get a different and longer pipe. I could feel that it sucked more when using the compressor and not the hand pump.
All finished
1. Warmed the oil to 40-50C
2. Turned off the car
3. loosened the filter 3 turns
4. waited 10 minutes, then removed the filter
5. turned the extractor on - it was quick and it really got the out last drop.
6. Fitted filter - remembering to oil the rubber seal
7. Filled 9L into the car
8. After 15 minutes, I checked the oil level - as you can see one mark down
9. Went for a drive
10. After 15 minutes, I checked the oil level - still down one mark
11. added the 400ml
A few drops of oil got onto the driveway when I disconnected the pipe from the car and it sprang from my hand.
A very easy job to do.
So the end of the filter looked a bit different. the one that come off the car was flat but the new one has a raised bit. It still clicked into place. I assume that it is ok. SDV8 AB MY 2020
Post #651379 21st Dec 2022 4:13pm
luxmoggy
The oil that I took out did seem thinner than the oil going in.
5.565 Dilution Factor of that oil. SDV8 AB MY 2020
Post #651380 21st Dec 2022 4:21pm
Page 3 of 3 <123
