One issue was getting the top off the pipe to suck the oil out. I didn't want to come off. I think I will buy a new one. It rotated off the bayonet fitting to come up about 1 cm, then would twist with pliers but not pull off. This was the longest part of the whole process.
![](https://www.fullfatrr.com/gallery/albums/userpics/22293/normal_04B534F8-7A06-488F-AEA4-AD73990AACF6.jpeg) | Click image to enlarge |
My €12 solution to level the car:
The extractor is connected to the car, next time I will get a different and longer pipe. I could feel that it sucked more when using the compressor and not the hand pump.
![](https://www.fullfatrr.com/gallery/albums/userpics/22293/normal_02404114-458A-4F6D-B1A3-9036282B63DF.jpeg) | Click image to enlarge |
All finished
1. Warmed the oil to 40-50C
2. Turned off the car
3. loosened the filter 3 turns
4. waited 10 minutes, then removed the filter
5. turned the extractor on - it was quick and it really got the out last drop.
6. Fitted filter - remembering to oil the rubber seal
7. Filled 9L into the car
8. After 15 minutes, I checked the oil level - as you can see one mark down
9. Went for a drive
10. After 15 minutes, I checked the oil level - still down one mark
11. added the 400ml
A few drops of oil got onto the driveway when I disconnected the pipe from the car and it sprang from my hand.
A very easy job to do.
So the end of the filter looked a bit different. the one that come off the car was flat but the new one has a raised bit. It still clicked into place. I assume that it is ok. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
