Home > Technical (L405) > Suspension fault when cornering
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Just had a warning show up with the above, suspension fault when cornering, any ideas what it could be, apart from expensive !!
Thanks
Post #649740 3rd Dec 2022 9:31am
mpirie
You have this topic under L405 but your profile has an L322 listed.
One's expensive to repair, the other's very expensive to repair! Thumbs Up
Mike
Post #649743 3rd Dec 2022 10:30am
Laughing
very true Mike... Thumbs Up ... - .- -.
Post #649745 3rd Dec 2022 10:33am
Wogger
Sorry not updated profile
I’ve got both, 322, and a 405.
That’s cheered me up no end !!
Could it just be a sensor fault?
The car seems to be driving ok
Post #649751 3rd Dec 2022 11:14am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
OP....find anything? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #651369 21st Dec 2022 3:44pm
MC
2013 Range Rover Autobiography SDV8 Santorini Black
Have you checked your ACE fluid level?
I recently had to replace the ACE pipes as they had corroded...
Post #652838 7th Jan 2023 11:27am
NoHandSignals
United States 2016 Range Rover 5.0 SC V8 Aruba
Hi,
I am new to the board. Just wondering if replacing the ACE pipes is something a reasonably experienced weekend mechanic could handle at home?
2016 L405 5.0 SC with C1119-09 (Permanent Hydraulic Pressure) error code and red suspension fault message to "Stop Safely Stop Safely Stop Engine. My ACE pipes are pretty rusty, so am thinking that is causing the pressure issue as I dont have any other error codes.
Thanks for the help and add Smile
[/img]
Post #672128 28th Aug 2023 1:27am
To do the job with original pipes you need to remove the rear subframe, download the Workshop Manual from the WIKI (link above right) It is a lot of work but doable for a home mechanic... I did hear rumours that the dealers charge up to £7,000 for doing it but that's probably a bit excessive...
Just a thought, if you removed both ends, worked out a new route for the pipes and got a flexible hydraulic hose made up it would be considerably quicker and cheaper than using new pipes which will just rust again.... Maybe it's possible.... Thumbs Up
The other answer is to rip the whole sway bars off and replace with the normal ones they fitted to the V6 diesel over here...!!
Never tried the above but in theory it should work.... maybe....!! Pete
Post #672139 28th Aug 2023 11:13am
NoHandSignals
Thanks for the vote of confidence! I ordered the factory pipes today for both front and rear. Should be here in a couple weeks.
Hopefully for the rear I can drop the subframe a little and snake the new pipes over it? Don't fancy dropping it out completely... eek Neutral
Some sort of replacement pipe, or perhaps cut and join with a hydraulic joint could be an alternative if I choke on this! Thanks for the suggestion Smile
Post #672221 29th Aug 2023 1:28am
Mikey
The pipes are too intricately shaped, and the subframe too close to the floor to cut them and rejoin without dropping the subframe...
Post #672227 29th Aug 2023 6:33am
NoHandSignals
Thanks, Mickey. I thought that might be the case as the pipes sure do look very intricately shaped!
..definitely going to be a learning experience. Smile
Post #672259 29th Aug 2023 12:19pm
Good to know, cheers... Thumbs Up Pete
Post #672264 29th Aug 2023 12:45pm
