Home > Technical (L405) > Suspension fault when cornering |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
You have this topic under L405 but your profile has an L322 listed.
3rd Dec 2022 9:30am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
3rd Dec 2022 9:33am |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 |
Sorry not updated profile
3rd Dec 2022 10:14am |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
OP....find anything? 2014 FF Autobiography 5.0 SC
21st Dec 2022 2:44pm |
MC Member Since: 08 Oct 2019 Location: UK Posts: 4 |
Have you checked your ACE fluid level?
7th Jan 2023 10:27am |
NoHandSignals Member Since: 28 Aug 2023 Location: MI Posts: 28 |
Hi,
28th Aug 2023 12:27am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
To do the job with original pipes you need to remove the rear subframe, download the Workshop Manual from the WIKI (link above right) It is a lot of work but doable for a home mechanic... I did hear rumours that the dealers charge up to £7,000 for doing it but that's probably a bit excessive...
28th Aug 2023 10:13am |
Thanks for the vote of confidence! I ordered the factory pipes today for both front and rear. Should be here in a couple weeks.
29th Aug 2023 12:28am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1750 |
The pipes are too intricately shaped, and the subframe too close to the floor to cut them and rejoin without dropping the subframe... |
29th Aug 2023 5:33am |
Thanks, Mickey. I thought that might be the case as the pipes sure do look very intricately shaped!
29th Aug 2023 11:19am |
Good to know, cheers... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
29th Aug 2023 11:45am |
