![]() | Home > Technical (L405) > Suspension fault when cornering |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 910 ![]() ![]() ![]() |
You have this topic under L405 but your profile has an L322 listed.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
Sorry not updated profile
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
OP....find anything? 2014 FF Autobiography 5.0 SC
MC Member Since: 08 Oct 2019 Location: UK Posts: 4 ![]() ![]() |
Have you checked your ACE fluid level?
NoHandSignals Member Since: 28 Aug 2023 Location: MI Posts: 31 ![]() ![]() ![]() |
Hi,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8543 ![]() ![]() ![]() |
To do the job with original pipes you need to remove the rear subframe, download the Workshop Manual from the WIKI (link above right) It is a lot of work but doable for a home mechanic... I did hear rumours that the dealers charge up to £7,000 for doing it but that's probably a bit excessive...
Thanks for the vote of confidence! I ordered the factory pipes today for both front and rear. Should be here in a couple weeks.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
The pipes are too intricately shaped, and the subframe too close to the floor to cut them and rejoin without dropping the subframe... |
Thanks, Mickey. I thought that might be the case as the pipes sure do look very intricately shaped!
Good to know, cheers... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
