Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help
Page 10 of 15 <123 ... 91011 ... 131415>
Seriouslthinkingaboutit
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Hi all
Can’t find anything with searches but can this be done on a 2007 L322. I’ve seen it’s been done on D3, D4 and an 06 RRS.
Thanks
Douglas
Post #630338 1st May 2022 11:29pm
Shedlock2000
Canada
Hi All,
I have a MY2010 5.0SC with vin AA and I have read through this thread with a close eye and still have a couple of queries. I am wondering if @georgekale or others could help:
Is there a wiring pigtail required to install the rear loadspace module to the vehicle harness, or is there a spare plug just dangling from the harness somewhere?
I believe that both front sensors are required for my AA VIN (it seems a bit unclear from the thread if I do or don't need both)? “The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.”
Post #635310 23rd Jun 2022 8:36pm
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
My Adaptive Cruise Control has not been working for a while and I've just been ignorring the Warning Messages after ignition. However, I now have some time and am trying to research and see what needs fixing.
The IID Comes up with the following:
CCM-Cruise Control
No data from ECU
Under IID Faults, I have the following Reported:
VIN: HIDDEN
L322 - Range Rover 2012
Vehicle scanned on 11-09-2022 15:15
Using IIDTool BT V3.0 B2643
BCM-Body Control
B1D17-87 (2F) Bus circuit - Bus signal/message failure - missing a message
( on 11-09-2022 15:14:38 at 161804 km )
- Test Failed
- Test Failed This Monitoring Cycle
- Confirmed
- Test Failed Since Last Clear
IPC-Instrument Pack
U0104-00 (2F) Lost communication with speed control module
( on 11-09-2022 15:14:42 at 161804 km )
- Test Failed
- Confirmed
PCM-Engine TDV8 4.4L
( on 11-09-2022 15:14:43 at 161804 km )
- Test Failed
- Confirmed
Could anybody confirm where the: Speed Control Module is located and is this diferent from the Radar Unit behind the Front Bumper discussed in this thread ?
Any advise on fault finding my problem ?
Many thanks,
Bob -------------------------------------
MY 2012 4.4 TDV8
Post #642684 11th Sep 2022 2:42pm
GraemeS
That is referring to the radar unit. Have you checked the fuse in the auxiliary fuse box?
Post #642724 11th Sep 2022 8:58pm
bwelton
Hi Graeme,
Is that Fuse 6 (Adaptive Cruise Control, Brake Light Switch) from the Glove Box ? I’ve tested that one and it’s Ok.
Any other thoughts from anybody ?
Thx Bob -------------------------------------
MY 2012 4.4 TDV8
Post #642731 12th Sep 2022 7:05am
GraemeS
The 10A engine bay fuse 17 is the main power supply for the radar unit. CJB fuse 6 supplies the ignition signal to the radar unit.
Post #642734 12th Sep 2022 8:10am
bwelton
Fuse 17 in the engine bay is also ok. I’ve also checked 12v+ on each side of all fuses within the engine Bay when the engine is running.
Other that that, are there any other control units to check before removing the Front Bumper to check / re-plug-in the Radar unit ?
Thx -------------------------------------
MY 2012 4.4 TDV8
Post #642738 12th Sep 2022 8:45am
GraemeS
The radar unit connects directly to the HS canbus, not via another module, so bumper off to check the connectors seems to be the next task.
Post #642744 12th Sep 2022 9:09am
mgrover
Put an offer in on a radar unit with serial
Quote:
BH32-9G768-AD
Will hopefully, order the rest once this turns up. Adding this to a L322 2011 4.4 TDV8.
PCM is already at latest. I take it I just need mounting bracket, loom and steering wheel controls? Or do I need the CC ecu as well?
If I do need the bracket will one from an L320 work?
Hopefully will stick a vid up of the install when I get it all together.
Cheers
Martin Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #651245 20th Dec 2022 11:24am
GraemeS
The 4.4's PCM provides CC/ACC functionality - no other ecu is required.
A L320 bracket could be quite different to the L322's bracket in how it mounts to the body.
Post #651247 20th Dec 2022 12:00pm
mgrover
ah fairs not worth the risk, got the radar for £200 delivered so a steal imo.
just need the loom, steering wheel bit, mount and away we go, already got the gap from a previous RRS, but I guess I'll need to get it activated.
do I still need to ask for the new firmware beta or do gap now just include it? Its actually a sport Sad
Post #651258 20th Dec 2022 2:24pm
GraemeS
I only needed special firmware because the radar unit that I bought was mis-described as it was from a Jag, not an L322, so had to have L322 firmware loaded before it would be recognised on the L322.
Post #651294 20th Dec 2022 7:53pm
ctjfb
Retrofit causing multiple errors...
I obtained a radar sensor, switches, and wiring loom from am MY 2012 (same as mine) - at lease I'm told that's what they were from - and the part numbers match the part catalog.
Buying the new bracket hurt a bit, but the installation was easy .. There was already a fuse in the slot in the engine fuse box.
That's the good bit ..
Once installed I used the GAP tutorial to set the three CCF values:
Cruise Control: Adaptive fitted
Cruise Control Display: Adaptive speed control full display plus priority messages
JAG Cruise Control: ACC
This completed OK
When the ignition was then turned on again I had multiple warnings. ABS Fault, Stability control, etc. etc. and the airbag light was illuminated.
A scan of fault codes just revealed one error logged by the Airbag module saying it had received an invalid config from the ABS module - this would not clear.
I reset all codes and still the ABS , traction control, airbag etc. warning light were illuminated along with many warnign messages.
I then edited the CCF again to return all value4s tp previous, but this had no effect on the above errors.
The only way I did then get rid of the messages and warning lights was to remove the ACC fuse for 10 seconds (with the config returned to no ACC) and all the faults & errors disappeared.
I tried the whole sequence again with exactlly the same results. The vehicle is perfectly happy with the radar sensor plugged in and powered, just so long as it's not configured as present in the CCF ....
Anyone else seen similar issues with the retrofit? Chris
2012 TDV8 4.4 Westminster
Post #658543 5th Mar 2023 4:24pm
GraemeS
I had to set more options than 3 but I also enabled stop/go. Check back through this thread to see what other CCF parameters need to be set.
Post #658577 5th Mar 2023 8:13pm
mgrover
Took a hail mary on this https://www.ebay.co.uk/itm/354828320570
Going to attempt to install on a 4.4 TDV8. i have the slim radar sensor. just need the bracket and wirign now. Its actually a sport Sad
Post #666447 12th Jun 2023 4:21pm
