![]() | Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help |
Shedlock2000 Member Since: 27 Feb 2015 Location: Lethbridge Posts: 15 ![]() ![]() |
Hi All,
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 137 ![]() ![]() ![]() |
My Adaptive Cruise Control has not been working for a while and I've just been ignorring the Warning Messages after ignition. However, I now have some time and am trying to research and see what needs fixing.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2566 ![]() ![]() ![]() |
That is referring to the radar unit. Have you checked the fuse in the auxiliary fuse box? |
Hi Graeme,
The 10A engine bay fuse 17 is the main power supply for the radar unit. CJB fuse 6 supplies the ignition signal to the radar unit. |
Fuse 17 in the engine bay is also ok. I’ve also checked 12v+ on each side of all fuses within the engine Bay when the engine is running.
The radar unit connects directly to the HS canbus, not via another module, so bumper off to check the connectors seems to be the next task. |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
Put an offer in on a radar unit with serial
Will hopefully, order the rest once this turns up. Adding this to a L322 2011 4.4 TDV8. PCM is already at latest. I take it I just need mounting bracket, loom and steering wheel controls? Or do I need the CC ecu as well? If I do need the bracket will one from an L320 work? Hopefully will stick a vid up of the install when I get it all together. Cheers Martin Its actually a sport ![]() Not anymore, 4.4 TDV8 now ![]() |
The 4.4's PCM provides CC/ACC functionality - no other ecu is required.
ah fairs not worth the risk, got the radar for £200 delivered so a steal imo.
I only needed special firmware because the radar unit that I bought was mis-described as it was from a Jag, not an L322, so had to have L322 firmware loaded before it would be recognised on the L322. |
ctjfb Member Since: 20 Jun 2019 Location: Northampton Posts: 32 ![]() ![]() |
I obtained a radar sensor, switches, and wiring loom from am MY 2012 (same as mine) - at lease I'm told that's what they were from - and the part numbers match the part catalog.
I had to set more options than 3 but I also enabled stop/go. Check back through this thread to see what other CCF parameters need to be set. |
Took a hail mary on this https://www.ebay.co.uk/itm/354828320570
