Home > Wheels & Tyres > Pirelli scorpions
TDV8 Paul
Pirelli scorpions
Right lads- I’m getting near tyre time and had a few what I’d consider brilliant tyres for the driving I do- one of my main requirements is the ability to minimise aquaplaning as much as physically possible- mainly because I use the M23 regularly to work and since they’ve resurfaced it- it’s absolutely shocking in the rain for standing water and add to that the unlit factor means there can be an unexpected wobble when you hit the wet stuff.
On these beasts the tyre of choice is the scorpions, I’m currently running good year f1’s which I like a lot, I’ve had the uniroyal rain sport 5’s which were also very good but I’ve seen so much about the Pirelli’s that I want to know are they really that good?
The mrs has them on her Audi q3 and I haven’t exactly thought ‘wow’ with them
Thoughts? 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #650947 16th Dec 2022 10:04pm
Phoenix
I've driven many FFRR's with different tyres on in different stages of wear, the Pirelli ones have always been the best compromise as a mixed use tyre. I would also say whichever you go for, make sure they are marked LR, the compound and sidewall strength etc. are tuned to manufacturer specifications and perform much better compared to the same tyre but with generic build spec.
I've just put four PIR 255/55 R20 110Y on mine, replacing some non-LR marked ones at around 3mm. The ride quality is markedly different.
https://www.ebay.co.uk/itm/155228440562 they were about £12 cheaper when I bought them just over a month ago.
Post #650948 16th Dec 2022 10:19pm
TDV8 Paul
That’s an interesting point as I did price some Pirelli’s up and I did come across a set with Land Rover in the ad! 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #650954 17th Dec 2022 1:23am
JayGee
I replaced my 7 yr old LR marked Verde’s to the same and there was a noticeable difference in ride quality and handling. I’d put this down to more a modern design, 3 mm vs 7mm tread and old age hardened rubber vs new. I’m not entirely convinced there are material differences between make specific and generic tyres of the same model but given there is no cost saving in not ticking the box it’s sensible to opt for it. 2012 TDV8 Vogue (L322)
Post #651042 18th Dec 2022 10:18am
LR branded tyres are known as homologated tyres, LR spends over two years and millions of £ fine tuning the tyres to be as good and safe as they can.
There is usually a significant difference in the make up of the tyre, from compound, to belts and other internal construction.
Drive them back to back with generic ones and you will notice a difference... Thumbs Up Pete
Post #651048 18th Dec 2022 11:23am
JayGee
What specific differences did you notice? 2012 TDV8 Vogue (L322)
Post #651052 18th Dec 2022 12:15pm
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Great question. Does LR homologation really make that much difference vs Mercedes, Audi or the vanilla version?
Post #651455 22nd Dec 2022 3:23pm
