![]() | Home > Maintenance & Mods (L322) > GAP IID - What next? |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 780 ![]() ![]() ![]() |
So, I've had my BT IID tool for a good couple of weeks and have thus far managed to clear historic faults and given my display an upgrade with the digital speedo.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
those little dots classified as drl's are a waste of time, they're not very effective John...
Mirrors fold on locking already. I thought that was standard on the 4.4's?
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
I would keep it in the FF Central Box, like I do with my IID Tool.
ttrw2 Member Since: 27 Dec 2015 Location: Oxfordshire Posts: 52 ![]() |
I use mine for: - fault checking/clearing - fiddling with settings like ride heights, dashboard (like you’ve already done) - logging parameters, e.g. gearbox solenoids and torque converter lockup, to check all is well |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
Mainly keep it for faults and for service resets, fuel pump priming for the FBH etc.
Set mpg offset back to 0%
Weird Member Since: 14 Dec 2022 Location: Maine Posts: 16 ![]() ![]() ![]() |
I’m sure there is a thread/s around here with all the 4.4 tweeks/manipulations that the GAP tool can perform, correct? |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
What the digital speedo upgrade in first post please. |
FYI, just pulled this from their site in case anyone is curious, possibly not the latest update though.
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
Gary RR - what’s the CCF setting for unlocking the doors? I had a look in the CCF file earlier and couldn’t see anything that looked like it, but know how these things can be termed under spurious names. I’ve assumed it’s under the BCM menu? Andy
For the digital speed readout and turning the DRLs on, I'll take a screenshot tomorrow of the settings.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Anybody changed the annoying headlight washers working same time as windscreen when headlights are on?
Not seen it in the standard CCF. Mine washes every 5th cycle of the screen wash which seems reasonable. 2012 TDV8 Vogue (L322) |
