Home > Maintenance & Mods (L322) > GAP IID - What next?
Page 1 of 3 123>
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
So, I've had my BT IID tool for a good couple of weeks and have thus far managed to clear historic faults and given my display an upgrade with the digital speedo.
Aside from that, it's back in its box and may never really be needed again until something goes wrong.
The question is, what else can I do with it?
I've heard about the DRL option, but unsure of what this will do other than keep my front LEDs burning all the time. Is it worth doing? Am I not just as well switching on my sidelights manually all the time? Whistle
With it being a Westminster from the final week of production, are any of the noted updates really worth doing?
Or should I just keep it in its box (like my AA card) for the 'what if.....'? The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #650657 13th Dec 2022 5:04pm
kevinp
I've done my drl's and they are just about ok, not as bright as modern day ones.
What about one press superlock?
Do your mirrors auto fold on locking?
Post #650659 13th Dec 2022 5:17pm
those little dots classified as drl's are a waste of time, they're not very effective John...
i would program a one key fob press for the superlocking and you can add a 'lock' and/or 'unlock' chirp. ... - .- -.
Post #650660 13th Dec 2022 5:19pm
JMC
Mirrors fold on locking already. I thought that was standard on the 4.4's?
One press superlock isn't required, as there's typically a large beast lurking in the boot! Laughing The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #650661 13th Dec 2022 5:21pm
Discotigger
I would keep it in the FF Central Box, like I do with my IID Tool.
Remember these are Range Rovers...there's no such thing as 'what if', it's a case of 'WHEN!' Rolling with laughter
I've had by IID Tool from when I got my first Rangie, an MY05 TD6, and it's been better than having an AA Card (which I also have, for when the IID Tool can't get you to a garage). It's been the most useful tool I've ever invested in, over the years it's proven its worth more than gold (or a fat wallet!).
Only yesterday it saved the day, when one of the rear parking sensors threw a wobbly due to the arctic temperatures we're currently experiencing and the PDC system quit working. Got the trusty IID Tool out, reset the fault on the PDC and all working again as it should.
IID Tool? Total value for money! Thumbs Up
Post #650670 13th Dec 2022 6:43pm
ttrw2
Re: GAP IID - What next?
I use mine for:
- fault checking/clearing
- fiddling with settings like ride heights, dashboard (like you’ve already done)
- logging parameters, e.g. gearbox solenoids and torque converter lockup, to check all is well
Post #650673 13th Dec 2022 7:07pm
garyRR
Mainly keep it for faults and for service resets, fuel pump priming for the FBH etc.
In terms of CCF changes, the useful ones I find are:
- DRLs - these in my opinion actually look really good and make the car seem a bit more modern. You can have them on, without needing the tail lights and sidelights on.
- MPH/KMH digital readout
- if not already configured, have the seat drop down on ignition off and door open, just like the steering wheel retracts?
- Unlock all doors on ignition off. This is one of the big gripes of many owners, and turns out this is possible (I recently set it) 2015 Range Rover Autobiography 4.4 SDV8
Post #650676 13th Dec 2022 7:15pm
JayGee
Set mpg offset back to 0%
Set new tyre size if you are running non standard sizes - the last 2 values in the CCF
Do a guided height calibration to take account of wear in the suspension over the years or if components have been recently changed.
Update the gearbox software using the paid feature.
Setup custom live value sets for things like DPF so you can quickly monitor parameters if needed. 2012 TDV8 Vogue (L322)
Post #650682 13th Dec 2022 8:05pm
Weird
United States 2008 Range Rover HSE 4.4 V8 Java Black
I’m sure there is a thread/s around here with all the 4.4 tweeks/manipulations that the GAP tool can perform, correct?
Post #650800 14th Dec 2022 10:39pm
johnboyairey
What the digital speedo upgrade in first post please.
Post #650805 14th Dec 2022 11:41pm
Weird
FYI, just pulled this from their site in case anyone is curious, possibly not the latest update though.
 08 l322 4.4 HSE Black/Jet.
Post #650807 15th Dec 2022 12:59am
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Gary RR - what’s the CCF setting for unlocking the doors? I had a look in the CCF file earlier and couldn’t see anything that looked like it, but know how these things can be termed under spurious names. I’ve assumed it’s under the BCM menu? Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration!
Post #650852 15th Dec 2022 11:37pm
garyRR
For the digital speed readout and turning the DRLs on, I'll take a screenshot tomorrow of the settings.
Here's with DRLs activated:
Here's how to enable unlock on ignition off (copied from my earlier post):
Turns out it is (now) possible, so long as you ask the right question:
It turns out you CAN get rid of one of the most annoying features on this car and have the doors unlock when you turn the engine off (note it might not work on pre 2010 cars).
So, the option doesn't appear in the standard CCF list so at some point you must have been given access to the entire CCF list.
After asking GAP again but this time to be granted access to the full CCF catalogue, sure enough, the option is hidden in there.
So, anyone wanting this and with an IID needs to write to GAP and request the access then, your CCF list will appear with this new option (basically the entire catalogue and not tested to make sure it does or doesnt work on your model so, be extra careful touching anything in here):
Then perform a search because there's hundreds of values in the catalogue. Select this one:
Change to Enabled and follow the procedure.
Warning to anyone who hasn't done a CCF change before, frightening things happen. Don't worry. Don't disconnect the tool or let the phone sleep whilst performing all the actions. Once completed, you will get lots of ECU errors on the driver display. Turn the ignition off, lock the car and leave it for 2 or 3 minutes so all ECUs go to sleep. Return and turn on the ignition, reconnect the IID and clear all fault codes and then use the car as normal. You'll need to set things like the clock, audio settings, speed warning, forward alert etc again.
The 'door unlock at engine off' feature seems to be quite clever when I tested it. It will only unlock the doors if they were previously locked by the 'drive away locking' feature. If you locked the doors manually with the dash button, when you turn the engine off, it knows this and keeps the doors locked for you. Very clever! 2015 Range Rover Autobiography 4.4 SDV8
Post #650855 16th Dec 2022 12:32am
DrRob
Anybody changed the annoying headlight washers working same time as windscreen when headlights are on?
Is it possible to switch this off?
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #650890 16th Dec 2022 12:10pm
JayGee
Not seen it in the standard CCF. Mine washes every 5th cycle of the screen wash which seems reasonable. 2012 TDV8 Vogue (L322)
Post #650892 16th Dec 2022 12:15pm
Page 1 of 3 123>
