Home > Maintenance & Mods (L405) > Getting ready for an oil change
Page 1 of 3 123>
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
So in the next couple of months, I will do my first oil change on the RR (the others have been at the stealers).
I want to work out what to order and check I am not overpaying.
Tools needed:
    Draper Oil Extractor 10l (160€) - or pump and old container (30€)
    36mm socket (in some places it says 32mm)
Oil - 9.5L (Jaguar Land Rover STJLR.03.5005)
    EUROLUB CLEANPOWER C1 SAE 5W-30 Engine Oil, 5L (27€) - never heard of this brand
    LIQUI MOLY 3729 Top Tec 4500 5W-30 5L (45€)
    Castrol Edge Professional Titanium FST C1 5W30 Diesel & Hybrid STJLR.03.5005 5L (50€)
Oil Filter
    LR022896
    MAHLE OX 153/7D2 Oil Filter (12.71€)
    Bosch P7112 Oil Filter Car (10€)
 SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #650420 10th Dec 2022 8:10pm
knwatkins
All looks about right Thumbs Up
PS. 36mm is correct Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #650425 10th Dec 2022 8:53pm
supershuttle
I got all that stuff it is correct 36mm and Mahle filter, however I got my oil from Smith and Allan as recommended on here, significantly cheaper and I did it myself Very Happy Geoff
Post #650429 10th Dec 2022 9:52pm
luxmoggy
S&A don't ship to Germany; the shipping cost might also wipe out any savings. Looking at lots of the different oils here I am looking at €70-€150 for 10L of oil. Castrol is about €100 to my door. So I will think I might go for that. But I will look for offers in the next month.
My driveway isn't completely flat. When I do the oil change how important is entirely flat? need to move the other car and then with the offroad mode measure if the car sees the slope. If I was to use the driveway is the slope one way better than the other? SDV8 AB MY 2020
Post #650622 13th Dec 2022 5:56am
knwatkins
My driveway has a gentle slope down towards the road and the nose of my car points down the slope. With my £10 little electric pump, I consistently pump 9.4 litres out of the engine which is the capacity of the sump. Obviously completely flat is best but not 100% critical. Thumbs Up Kev
Post #650625 13th Dec 2022 6:46am
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
I would add drip tray/big piece of cardboard under the engine bay. I was surprised how much oil there was in the filter housing when I did mine even though i have done many oil changes over the years and not surprisingly some of it made its way to the floor as i moved the filter housing and filter. Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #650631 13th Dec 2022 8:24am
Kot
Torque wrench for the new oil filter, otherwise it will leak Whistle
Otherwise you wont know its leaking till the bottom tray overflows and drips on to your drive Big Cry
The tipex marks just dont cut it Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #650632 13th Dec 2022 9:18am
Kot
Through oil dilution, I usually get 10l or a little over so I stop at 9L empty old oil and start again so there are no overflows. 2018 SE SDV8 4.4 Byron Blue
Post #650633 13th Dec 2022 9:22am
johnboyairey
its relatively straighforward as above, take time unscrewing filter so it drains back, and doesnt flood as you lift it off. change the O rings on the filter holder too. i use the smith allen oil too. you can do 2 changes with filters for about £100 and still have some spare oil. i measure out the oil in an old milk jug, so i know how many full litres are going in. via a decent funnel. then run it, and check via screen buttons.
Post #650645 13th Dec 2022 1:07pm
Gremlin500
@Luxmoggy,
If your driveway isn’t flat and you are a perfectionist, it’s easy enough to stick the rear on axle stands on the downhill end to get it level? Plus, all that jacking work will keep you warm! Whistle “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #650647 13th Dec 2022 1:59pm
luxmoggy
Laughing Laughing It is the side to side which I need to make level. I parked on the most level part of the driveway where axle stands could be used. In the 4x4 screen. It shows front/back -3 correct as going downhill. But -5 for drives to the passenger side. I will get some small ramps to use on one side of the car.
One day when the kit car is finished I could do the oil change in the garage.
True that Smith&Allan is half the price, but with shipping and customs. Maybe on my next visit to the UK, I could pick up 20L. SDV8 AB MY 2020
Post #650654 13th Dec 2022 2:59pm
Kot
Rolling with laughter i use the wife's pyrex measuring jug Rolling with laughter a litre at a time. Its mine now, hidden in the garage Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #650668 13th Dec 2022 5:38pm
luxmoggy
I am going to buy a set of oil jugs with flexible funnels. Then my children won't use them for anything else. I need the one in the kitchen for cooking. Cool SDV8 AB MY 2020
Post #650674 13th Dec 2022 6:07pm
johnboyairey
Come next pancake day, your wife will offer you a couple, then you’ll take your empty plate over to the sink, and see that jug with the pancake mix inside… and grind your teeth a little!
Post #650694 13th Dec 2022 11:49pm
Gremlin500
Yes, the result of all this is, it’s useful to have a wife with a decent set of jugs! Rolling with laughter Rolling with laughter Rolling with laughter
However, I am wary of an invitation to several of your households due to fear of oil inebriation Thud Shocked “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #650695 14th Dec 2022 12:14am
Page 1 of 3 123>
