Home > Maintenance & Mods (L405) > Getting ready for an oil change |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
All looks about right
10th Dec 2022 8:53pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3778 |
I got all that stuff it is correct 36mm and Mahle filter, however I got my oil from Smith and Allan as recommended on here, significantly cheaper and I did it myself Geoff |
10th Dec 2022 9:52pm |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 461 |
S&A don't ship to Germany; the shipping cost might also wipe out any savings. Looking at lots of the different oils here I am looking at €70-€150 for 10L of oil. Castrol is about €100 to my door. So I will think I might go for that. But I will look for offers in the next month.
13th Dec 2022 5:56am |
My driveway has a gentle slope down towards the road and the nose of my car points down the slope. With my £10 little electric pump, I consistently pump 9.4 litres out of the engine which is the capacity of the sump. Obviously completely flat is best but not 100% critical. Kev
13th Dec 2022 6:46am |
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 117 |
I would add drip tray/big piece of cardboard under the engine bay. I was surprised how much oil there was in the filter housing when I did mine even though i have done many oil changes over the years and not surprisingly some of it made its way to the floor as i moved the filter housing and filter. Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
13th Dec 2022 8:24am |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1194 |
Torque wrench for the new oil filter, otherwise it will leak
13th Dec 2022 9:18am |
Through oil dilution, I usually get 10l or a little over so I stop at 9L empty old oil and start again so there are no overflows. 2018 SE SDV8 4.4 Byron Blue |
13th Dec 2022 9:22am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
its relatively straighforward as above, take time unscrewing filter so it drains back, and doesnt flood as you lift it off. change the O rings on the filter holder too. i use the smith allen oil too. you can do 2 changes with filters for about £100 and still have some spare oil. i measure out the oil in an old milk jug, so i know how many full litres are going in. via a decent funnel. then run it, and check via screen buttons. |
13th Dec 2022 1:07pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1418 |
@Luxmoggy,
13th Dec 2022 1:59pm |
It is the side to side which I need to make level. I parked on the most level part of the driveway where axle stands could be used. In the 4x4 screen. It shows front/back -3 correct as going downhill. But -5 for drives to the passenger side. I will get some small ramps to use on one side of the car.
13th Dec 2022 2:59pm |
i use the wife's pyrex measuring jug a litre at a time. Its mine now, hidden in the garage 2018 SE SDV8 4.4 Byron Blue |
13th Dec 2022 5:38pm |
I am going to buy a set of oil jugs with flexible funnels. Then my children won't use them for anything else. I need the one in the kitchen for cooking. SDV8 AB MY 2020
13th Dec 2022 6:07pm |
Come next pancake day, your wife will offer you a couple, then you’ll take your empty plate over to the sink, and see that jug with the pancake mix inside… and grind your teeth a little! |
13th Dec 2022 11:49pm |
Yes, the result of all this is, it’s useful to have a wife with a decent set of jugs!
14th Dec 2022 12:14am |
