Home > Maintenance & Mods (L405) > l405 battery
Page 6 of 8 <12345678>
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
So with the charger connected under the bonnet, I am monitoring the batteries. It only seems to charge the main battery.
When driving I saw both charging at the same time, but can confirm that.
This morning I wanted the FBH to turn on as it was -3C. It didn't I think due to the main battery being low. When I parked the car last night. There were a few trips to the car for the shopping and other bits. This I think dropped the main battery down.
I triggered it another 2 times during the day today after driving. Making sure I just closed and locked the car when I turned off the engine. It worked both times.
The next time to drive the car is Monday morning when it is going to be about -4C. I check the battery level and start the FBH from the phone.
Looking at the monitor I can't see anytime that the secondary battery has been used. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #650422 10th Dec 2022 8:26pm
luxmoggy
The last 2 mornings I have used FBH before getting into the car. It drops the main battery voltage by at least 0.5V. If the battery is a bit low at the end of a journey I can see this causing issues.
Again the AUX battery isn't being used. SDV8 AB MY 2020
Post #650623 13th Dec 2022 6:16am
knwatkins
The auxiliary battery is only switched into the circuit to provide extra current capacity during starting Thumbs Up Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #650626 13th Dec 2022 6:48am
luxmoggy
Ok. It doesn’t seem to have got to a level where it needs to do so. SDV8 AB MY 2020
Post #650628 13th Dec 2022 7:20am
Phoenix
The aux. battery should be in circuit during cranking, it's main function is to prevent electrical disturbance during cranking (lights flickering etc.) they were introduced as part of the autostop functionality.
Post #650629 13th Dec 2022 7:29am
luxmoggy
Last night there was a drain on the main Battery. I don't know what it was - maybe the monitor I have plugged in for the soot. After some time, I saw that the Main and Aux connected together to raise the voltage in the main battery.
I expect that when I get in the car there will be a low voltage warning but the car will start without issues. SDV8 AB MY 2020
Post #650859 16th Dec 2022 6:03am
luxmoggy
The FBH started and then stopped due to the low main battery - that was expected. The AUX (secondary) battery was used to help the main battery start the RR. So it helped jump itself. It was -10C here overnight.
I will check the car doesn't drain over the next few days. When at home and know that I want to use FBH in the morning attach the CTeK overnight. Don't worry about the main battery voltage. SDV8 AB MY 2020
Post #650866 16th Dec 2022 8:18am
Muiryden
United Kingdom 2013 Range Rover Autobiography SDV8 Aintree Green
Changed my battery today as it was struggling in the cold. Only lasted 10 years and 210k miles 😮
Post #685299 10th Feb 2024 9:55pm
AnnualMan
Switzerland
Do you need to reset the BMS when replacing the auxiliary battery, or just the main battery? 2018 P400e AB LWB
Post #689317 29th Mar 2024 11:55am
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
Each battery has its own BMS control module. It is the chunk of metal on the negative terminal. Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #689325 29th Mar 2024 2:17pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys my local garage said my battery may need changing but I got no fault codes or warning on dash etc.. car starts first time no issues here are some reads I took with GAP tool first while engine running after 5 mins second engine off after 5 mins. Are they both due a change even though I’m experiencing no issues?
 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #689579 1st Apr 2024 12:28pm
Jorrocks
United Kingdom 2018 Range Rover Autobiography SDV8 Montalcino Red
As I don’t have a Gap tool, if I replace my batteries myself will the car start so that I can drive to my Indy for the software bit to be done? 2018 L405 4.4 SDV8 Autobiography
2010 L322 3.6 TDV8 Vogue SE, 171000 miles and counting….
Post #692160 8th May 2024 3:37pm
Jorrocks
Further to my last post, has anyone managed / bothered to shoehorn an 020 battery into their 405? Same width and height as the standard 019, but 393mm rather than 353mm. 2018 L405 4.4 SDV8 Autobiography
Post #692165 8th May 2024 4:10pm
My new batteries arrived today - purely preventative maintenance as I've had no issues so far. However, as they are the original batteries and the car is over 10 years old, it does feel like I'm on borrowed time Laughing
I went with Exides from Tayna - an EK950 & an EK700 - total £267 inc delivery
@Jorrocks - I think you'd be fine. Some others have reported not bothering at all. I was wondering but I discovered that the cheap code reader I bought - an Autel Maxi AP200 will apparently do the battery registration job Cool
I just need to get around to fitting them now.
Post #692176 8th May 2024 5:49pm
caymanblack
I replaced my two with the same as Alistair bought, and everything works much better now. overfinch modified
Post #692179 8th May 2024 6:36pm
