Home > Technical (L405) > Boot with a mind of it's own... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Use the button inside, top and bottom tailgate open fully and close fully
9th Dec 2022 5:44pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1422 |
#2
9th Dec 2022 6:30pm |
Cheers, I'll give it a go... Pete
9th Dec 2022 6:31pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
Mine is the same Pete, definitely down to battery charge, only other problem I have which I am sure you do is getting out the way quick enough to avoid getting decapitated |
9th Dec 2022 6:49pm |
Maybe my battery is worse than yours as it doesn't move fast enough to hit anything....!!!
9th Dec 2022 7:10pm |
Maybe, everything else is great, however I get 'low battery start engine' warning when towing, and tailgate dicks about when button pressed, assume leisure battery in trailer drains it somewhat, otherwise fine didn't realise there are 2 batteries, oh Jesus |
9th Dec 2022 8:07pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Try it with a charger connected, if it's OK, you know it's voltage related. |
9th Dec 2022 8:09pm |
Never had the 'low battery start engine' warning
9th Dec 2022 8:26pm |
If you have a low current charger, that'd be best - it'll lift the voltage a bit but not so much that the motors operate entirely off the charger. If not, put the lights on to draw off some of the charger output. IIRC the 'low voltage - start engine' needs the voltage to be low for a period of time to stop transient current draw repeatedly triggering the message. |
9th Dec 2022 8:48pm |
Pete
9th Dec 2022 10:37pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
I’m finding that mine shows similar idiosyncrasy as the OP. I don’t feel that my battery is low as it starts the engine very strongly. I think the seals at the side of the upper tailgate brush against the rear pillars slightly and that depending on the circumstances, its enough for the motor to sense an obstruction, so stops. I don’t think it takes much for the motors to sense obstruction, so even the slightest change in speed brings it below the threshold to stop. V8 or else ... |
10th Dec 2022 10:06am |
Fisha,
10th Dec 2022 10:16am |
