Home > Maintenance & Mods (L405) > l405 battery
Page 4 of 8 <12345678>
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
This is directly on the battery. I already have a cTek connector under the bonnet. I am going to a monitor and charging cable on the battery. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #649931 5th Dec 2022 8:04pm
Gremlin500
………. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #649932 5th Dec 2022 8:10pm
luxmoggy
So on the main battery, I have connected a monitor. I will order another one for the second Battery. Just to really see what is going on.
Is there any documentation about when both batteries are connected together? E.g. if voltage falls under a value? when the car is on terminals under the bonnet? I have a strange graph for the overnight voltage. it drops and then jumps up and slowly drops again.
I thinking about some of the readings that I got when charging the car using the terminals under the bonnet. The higher charging voltage was only on the secondary battery, not the main one. So I now think that I will also charge the main battery directly at times.
The voltage reading under the bonnet is higher than the main battery but lower than the secondary. When I was doing these reading the car was active so the batteries were in parallel. At other times they are separate and supply different circuits.
I like trying to get to the bottom of a puzzle. SDV8 AB MY 2020
Post #649958 6th Dec 2022 6:35am
luxmoggy
The main battery was replaced today. With the GAP Tool (Beta), the action of the main battery replacement was done.
The battery monitor is reading 12.52V. I need to drive the car a bit more or I might charge the battery overnight.
To have peace of mind I have ordered a new secondary battery, I can hopefully replace that on Friday. SDV8 AB MY 2020
Post #650012 6th Dec 2022 6:51pm
luxmoggy
So I have disconnected the charger. I am watching the voltage of the main battery via the App. It has a reading of around 12.8v. Which is so much better than the old battery. I will fit the other battery and monitor on Friday. I am happy that I have done this. SDV8 AB MY 2020
Post #650101 7th Dec 2022 4:44pm
Gremlin500
Post #650104 7th Dec 2022 5:00pm
luxmoggy
So I fitted the second battery today. The Breather pipe doesn't fit into the battery, they changed the clamp in the later car and the battery from Land Rover has the breather hole offset. So either I drill a hole in the clamp or go for an original battery.
On the main battery, it was going well. But part way through the journey today (looking at the monitor) the battery was no longer charging. So at the end of the journey. 3 trips of 40 minutes each. The battery was in a lower-charged state. I think it will be hard to find this issue. I need to do a long journey tomorrow for the Active ReGen I will keep an eye on the battery levels. SDV8 AB MY 2020
Post #650197 8th Dec 2022 8:49pm
qwerty
2016 Range Rover Autobiography SDV8 Carpathian Grey
Be careful not to 'over think it ', the alternator is a smart charger so I am guessing at times it lets the battery drop to a predetermined level?
Post #650201 8th Dec 2022 9:09pm
luxmoggy
The main battery was at 12.9V when I started the 3 trips and 12.2V when I finished. That is the part I found odd. SDV8 AB MY 2020
Post #650202 8th Dec 2022 9:15pm
qwerty
I would have thought that was ok, the monitoring system managing the charge between set upper and lower limits? Maybe someone with more knowledge could confirm as it would be usefull to know. Thumbs Up
Post #650203 8th Dec 2022 9:25pm
Phoenix
Charge level (not voltage) is intentionally maintained ~80% which would fit with your recorded voltage - some of which will recover once the vehicle is 'sleeping' The key thing is that the generator can support the vehicle load andcharge the battery as required. A new battery will most likely be above 80% charge - and if the BMS has been reset, then there will be a learning period.
Post #650205 8th Dec 2022 9:43pm
supershuttle
I probably should know this my car doesn't have stop/start but I am thinking a new battery is a good idea (wouldn't start today in freezing conditions) its an early L405 so I am assuming its AGM but does anyone have any specific recommendation? Geoff
Post #650207 8th Dec 2022 9:50pm
Phoenix
Bosch S5A13 019 is standard size fit, you can squeeze an S5A15 020 in for max. amps - just.
Although mine is non-autostop, I've not had any issues with voltage dip on cranking or FBH preheat not running or shutting down prematurely. It costs more than a standard AGM but IMO worth the extra for the lack of low voltage issues and anomalies that 'just happen' I don't do a lot of miles for five days a week so I wanted something that was resilient enough to stand up to winter temperatures and usage before it got a decent amount of use at the weekends.
Post #650220 8th Dec 2022 11:08pm
supershuttle
Quick follow up question, the handbook says remove the battery to charge it. That will be a royal ballache or at the very least backache so can I just connect my c-tek to the jump start terminals under the bonnet. Geoff
Post #650233 9th Dec 2022 9:34am
luxmoggy
Yes you can. I have a Ctek quick connect attached to them. It charges the battery well. SDV8 AB MY 2020
Post #650237 9th Dec 2022 10:26am
