![]() | Home > Technical (L322) > Static Bending Lamps |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Mine come on when I'm driving less than about 30mph and I turn a tightish bend, such as turning into a side road.
silly question but can you see the bulbs in the headlamp, V8 facelift Range Rover Autobiography 22" wheels.
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Yeah - the bulbs are fitted and the elements look OK ! I haven't tried to replace them right enough. |
Do they come on without the indicators being on ? and can you tell me if they come on when stationary when you turn the steering wheel or do you need to be moving ? |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
Hi yeah they work when stationary. |
you do need to be moving and i am pretty sure they will come on even if the indicator is not used. have you checked your fuses... V8 facelift Range Rover Autobiography 22" wheels.
yeah, fuses OK as well - I'll try a different bulb first, although, I wouldn't imagine that both bulbs are blown !! |
you never know they may have been disconnected as they have a habit of burning the chrome inners, V8 facelift Range Rover Autobiography 22" wheels.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
I have a feeling that this facility can be turned on or off by programming? Got - 2017 SDV8 Autobiography in Loire Blue
Might be. I know LR had some probs with the lights melting the housing in situations where they were on for longer periods (such as traffic). |
Mine work when I just turn the wheel in park. ![]() |
i thought they stopped that... as that's what was melting the chrome housing and it dont take long to do it... V8 facelift Range Rover Autobiography 22" wheels.
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
OK def work when stationary. They are active only when the engine is running, the headlamps are on and reverse gear is not selected.
Unnecessary quote removed
