Home > Technical (L322) > Static Bending Lamps
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
I've got a 2005 Supercharged that has the adaptive headlamps and "static bending lamps" as they are called in the manual - I can't seem to get these additional lights to come on.
I've read elsewhere that they are supposed to come on below a certain speed when the steering is activated or the indicators are activated but mine won't come on at all.
Can anyone enlighten me ?!?!
Thanks
Colin
Post #64888 19th May 2011 8:12pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Mine come on when I'm driving less than about 30mph and I turn a tightish bend, such as turning into a side road.
If they are working you will see the road light up on the inside edge of the turn. They are quite bright so I doubt you would miss this, perhaps your bulbs need replacing?
Gone - Range Rover Supercharged 2006
Post #64901 19th May 2011 8:50pm
daveo
silly question but can you see the bulbs in the headlamp, V8 facelift Range Rover Autobiography 22" wheels.
Post #64906 19th May 2011 8:55pm
CG-SC
Yeah - the bulbs are fitted and the elements look OK ! I haven't tried to replace them right enough.
Post #64922 19th May 2011 9:52pm
CG-SC
Do they come on without the indicators being on ? and can you tell me if they come on when stationary when you turn the steering wheel or do you need to be moving ?
Post #64924 19th May 2011 9:53pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Hi yeah they work when stationary.
Post #64930 19th May 2011 10:00pm
daveo
you do need to be moving and i am pretty sure they will come on even if the indicator is not used. have you checked your fuses... V8 facelift Range Rover Autobiography 22" wheels.
Post #64931 19th May 2011 10:00pm
CG-SC
yeah, fuses OK as well - I'll try a different bulb first, although, I wouldn't imagine that both bulbs are blown !!
Post #64934 19th May 2011 10:11pm
daveo
you never know they may have been disconnected as they have a habit of burning the chrome inners, V8 facelift Range Rover Autobiography 22" wheels.
Post #64935 19th May 2011 10:40pm
I have a feeling that this facility can be turned on or off by programming? Got - 2017 SDV8 Autobiography in Loire Blue
Post #64936 19th May 2011 10:46pm
SteveMFr
Site Sponsor
Might be. I know LR had some probs with the lights melting the housing in situations where they were on for longer periods (such as traffic).
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #64967 20th May 2011 9:24am
Stephen.125
Mine work when I just turn the wheel in park. Embarassed
Post #65009 20th May 2011 11:14am
daveo
i thought they stopped that... as that's what was melting the chrome housing and it dont take long to do it... V8 facelift Range Rover Autobiography 22" wheels.
Post #65049 20th May 2011 2:51pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
OK def work when stationary. They are active only when the engine is running, the headlamps are on and reverse gear is not selected.
The AFS takes inputs from a number of systems including:
Steering angle sensor
Vehicle Speed
Headlamp Status
Reverse gear selector
Engine Running Status
Automatic Lights on
It is also worth noting that the static bending lamps are ultimately controlled by the lighting control module, the AFS Module sends a request to the LCM for them to be lit. Main AFS control for the headlamp is direct from AFS module to headlamp via a private LIN.
Quick question, when you turn the ignition on do your headlamp calibrate? by that can you see the beams motor inwards and dow before resetting level?
If not just buy a new AFS (Adaptive Front Lighting System) module. It is just plug and play with no programming needed and is the same part as the RRS an D3/4. It not very cheap at about £140 IIRC but you may find one on ebay. They are common between all pre and post facelift models (not too sure about 10MY onwards) and it is located behind the interior trim panel at the bottom of the passenger a pillar, 2 mins work to replace.
I spent a long time chasing why mine weren't work without the AFS fail light on. I isolated a blown bulb in the cluster by disconnecting the module and the warning illuminated. Turned out to be the AFS module and now all is working fine.
Steve 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #65164 21st May 2011 9:29am
CG-SC
Unnecessary quote removed
Thanks for all the help - I'll need to investigate further !
Post #65182 21st May 2011 11:36am
