Home > Technical (L405) > L405 driver door stuck shut |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 94 |
Have you tried the physical key found in the fob? |
30th Nov 2022 5:12am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35246 |
frozen?......what temperature do you have there.. ... - .- -.
30th Nov 2022 7:49am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1182 |
There is a youtube video of Raymies garage same problem. something to do with the soft close, It could be worth a look. |
30th Nov 2022 8:26am |
3RangiesIn Member Since: 30 Nov 2022 Location: rm16 6ly Posts: 11 |
Hi, Thanks for the replies.
30th Nov 2022 1:28pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1184 |
So for a MY18 WSM states below presume MY13 cant be much different have you checked the wiki for your MY13? Door will not unlock - One door only Damaged electrical harness Door Module failure Door Module software requires updating Exterior handle release cable preload / twisted Door latch internal failure Door will not lock - One door only Damaged electrical harness Door Module failure Door Module software requires updating Door latch internal failure 2018 SE SDV8 4.4 Byron Blue |
30th Nov 2022 1:52pm |
So if Emergency key doesn't work here are extra fault findings
30th Nov 2022 1:54pm |
Hi Kot
30th Nov 2022 1:59pm |
PM me with your email if you want the pdf for the door shows you how to access fault find and pics etc 2018 SE SDV8 4.4 Byron Blue |
30th Nov 2022 2:49pm |
Hi Guys
1st Dec 2022 3:46pm |
check the battery.... ... - .- -.
1st Dec 2022 4:20pm |
The range rover is a conundrum wrapped in an enigma. Low battery causes 1 door to refuse to open and the others work fine! |
1st Dec 2022 5:10pm |
Unless you have a very good battery gremlins start to get in.
1st Dec 2022 6:31pm |
Hi Tinman
1st Dec 2022 7:49pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1383 |
Oi, Tinman, I resemble that remark! Yes, I also think a new battery is on the cards, fullfats like nithing more than a new battery, yum-yum! Think of your battery like diesel/petrol/screenwash/oil/brake pads etc. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
1st Dec 2022 8:20pm |
