Home > Technical (L405) > L405 driver door stuck shut
3RangiesIn
long time lurker finally joins
I have a 2013 RANGE ROVER 4.4 sd vogue se, today, the driver's door will not open, either from the inside or outside. Using the remote or door buttons, have no effect. It seems permanently stuck. The other doors work fine, lock unlocks with the remote and internal buttons.
Post #649506 30th Nov 2022 1:29am
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
Have you tried the physical key found in the fob?
Post #649507 30th Nov 2022 5:12am
frozen?......what temperature do you have there.. ... - .- -.
Post #649512 30th Nov 2022 7:49am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
There is a youtube video of Raymies garage same problem. something to do with the soft close, It could be worth a look.
Post #649515 30th Nov 2022 8:26am
3RangiesIn
Hi, Thanks for the replies.
Marcochezzi- tried that would not open.
Stan- I'm in Essex,UK so temp is 9
Tinman- I will watch the video.
I have had this Full fat since July 2020, with absolutely no issues, so far she has been good to me!
Post #649541 30th Nov 2022 1:28pm
Kot
Re: L405 driver door stuck shut
So for a MY18 WSM states below presume MY13 cant be much different have you checked the wiki for your MY13?
Door will not unlock - One door only
Damaged electrical harness
Door Module failure
Door Module software requires updating
Exterior handle release cable preload / twisted
Door latch internal failure
Door will not lock - One door only
Door Module failure
Door latch internal failure 2018 SE SDV8 4.4 Byron Blue
Post #649543 30th Nov 2022 1:52pm
Kot
So if Emergency key doesn't work here are extra fault findings
Door will not lock/unlock mechanically using the emergency key barrel
Exterior door handle damaged
Emergency key barrel cable disconnected from the emergency key barrel
Emergency key barrel cable disconnected from the door latch
Emergency key barrel internal failure 2018 SE SDV8 4.4 Byron Blue
Post #649545 30th Nov 2022 1:54pm
3RangiesIn
Hi Kot
You have been very helpful, now I know where to look. Thank you
Post #649546 30th Nov 2022 1:59pm
Kot
PM me with your email if you want the pdf for the door shows you how to access fault find and pics etc 2018 SE SDV8 4.4 Byron Blue
Post #649548 30th Nov 2022 2:49pm
3RangiesIn
Hi Guys
This morning, pressed the open button on the remote, and lights flashed, this time, No doors would unlock!,what fresh hell is this?
tried again, lights flashed, muted unlocking sounds. doors will not open. WTF!
then tried boot doors, they opened and then closed as normal. Tried to open the doors again, stuck fast! I HATE MY RANGE ROVER! Big Cry
I tried the boot doors again, they opened and closed as normal. Visions of massive £££££ to be spent before Christmas. Censored
Then I tried to open again, then,it worked! normal unlocking sounds, driver's door opens, and all doors work fine! my beloved FULL FAT IS BACK TO NORMAL Thumbs Up
I don't know what happened, maybe the Range rover electrical gremlins messing with me.
I LOVE MY RANGE ROVER, THE AFFAIR CONTINUES Very Happy
Thanks to all who gave advice Bow down
Post #649628 1st Dec 2022 3:46pm
check the battery.... Thumbs Up ... - .- -.
Post #649630 1st Dec 2022 4:20pm
3RangiesIn
The range rover is a conundrum wrapped in an enigma. Low battery causes 1 door to refuse to open and the others work fine! Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Post #649639 1st Dec 2022 5:10pm
Tinman
Unless you have a very good battery gremlins start to get in.
What is the state of your battery and how old?
Post #649644 1st Dec 2022 6:31pm
3RangiesIn
Hi Tinman
Now here's a thing, it was supposed to be new in 2020,but it says "low battery"(probably every 6 weeks), is that because the battery may be crapped out or due to my life change, I don't do much driving,these days,4k a year. Consequently, battery juiced up via ctek
Post #649651 1st Dec 2022 7:49pm
Gremlin500
Oi, Tinman, I resemble that remark! Rolling with laughter
Yes, I also think a new battery is on the cards, fullfats like nithing more than a new battery, yum-yum! Mr. Green
Think of your battery like diesel/petrol/screenwash/oil/brake pads etc. Laughing “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #649652 1st Dec 2022 8:20pm
