![]() | Home > Technical (L405) > L405 driver door stuck shut |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 96 ![]() ![]() ![]() |
Have you tried the physical key found in the fob? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
frozen?......what temperature do you have there.. ... - .- -.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
There is a youtube video of Raymies garage same problem. something to do with the soft close, It could be worth a look. |
3RangiesIn Member Since: 30 Nov 2022 Location: rm16 6ly Posts: 11 ![]() ![]() |
Hi, Thanks for the replies.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1261 ![]() ![]() |
So for a MY18 WSM states below presume MY13 cant be much different have you checked the wiki for your MY13? Door will not unlock - One door only Damaged electrical harness Door Module failure Door Module software requires updating Exterior handle release cable preload / twisted Door latch internal failure Door will not lock - One door only Damaged electrical harness Door Module failure Door Module software requires updating Door latch internal failure 2018 SE SDV8 4.4 Byron Blue |
So if Emergency key doesn't work here are extra fault findings
Hi Kot
PM me with your email if you want the pdf for the door shows you how to access fault find and pics etc 2018 SE SDV8 4.4 Byron Blue |
Hi Guys
check the battery.... |
The range rover is a conundrum wrapped in an enigma. Low battery causes 1 door to refuse to open and the others work fine! |
Unless you have a very good battery gremlins start to get in.
Hi Tinman
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1587 ![]() ![]() ![]() |
Oi, Tinman, I resemble that remark! ![]() Yes, I also think a new battery is on the cards, fullfats like nithing more than a new battery, yum-yum! ![]() Think of your battery like diesel/petrol/screenwash/oil/brake pads etc. ![]() |
