Home > Technical (L322) > FBH - a Range Rover story |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 122 |
As per the first posts of this thread, when the FBH starts the fan will run and the unit self-checks the operation of the various system components. If any aren’t present it will shut down. This is usually after 2.5 mins of start up and a system fault will be logged. From what I recall, 3 failed attempts at starting the FBH will lock itself out until it is reset by removing and refitting the fuse. Typical causes for failed start are: Battery voltage lower than 10 volts; glow plug open or short circuit; circulation pump open or short circuit, PCB board fault and finally fuel dosing pump failed thus no fuel to the heater. I can’t speak for FFRR’s but in my experience with FBH’s in other cars the dosing pump is often the culprit. It is solenoid operated, so you should be able to hear it and feel it clicking. As these can stick after long periods of inactivity. A gentle tap with a hammer will sometimes work. Worth looking at |
3rd Jan 2021 10:54pm |
Maccaa Member Since: 03 Feb 2020 Location: Bristol Posts: 38 |
jonnyboy54321
11th Jan 2021 4:27pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
search for French mike on here and you will see los of posts andnthings folks have done to fix FBD+H.
11th Jan 2021 4:38pm |
Thanks for the contact details Dolphinboy, I think my head is numb with all the data I've taken on board over FBH's but the glow plug is showing as faulty on the Webasto software, but the FBH works when the car is running, so I'm erring on a check of the ECU as this seems an inherent ECU issue throughout a number of thread s that I've digested.
11th Jan 2021 4:42pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
So how do you know if you have FBH was it a standard fitment? an extra or comes with certain models? 2012 Vogue 4.4 TDV8 - Current
11th Jan 2021 6:41pm |
Al diesels have an FBH (to heat the engine up quicker as these run very cool and will affect heating and efficiency otherwise.) Some petrols have them as an option (my 2004 Autobiography does).
11th Jan 2021 9:43pm |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
I also has a lot of problems last winter with FBH. Sometime it works, sometime not. But even when it works, there was other things I dont like.
28th Sep 2022 6:52pm |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
Some pictures of the valve mod would be nice SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
28th Sep 2022 10:44pm |
I done this last winter. It was cold and unfortunately didnt take any pictures.
29th Sep 2022 6:53am |
Love your work Mate! SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
29th Sep 2022 7:29am |
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 |
Does anyone have a link to the thread about mentioned PCB problems with resistors?
29th Nov 2022 9:42pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
There's a link in the thread posted above to it, here's the one I found useful. https://www.the75andztclub.co.uk/forum/showthread.php?t=53896 |
29th Nov 2022 9:50pm |
