Home > Technical (L322) > FBH - a Range Rover story
Page 3 of 4 <1234>
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
thanks, but What is the purpose of this heater, is it to keep the engine warm over night, I remember there used to be electric ones that plugged in to the mains power, doctors used them in case they were called out in the night.
Is it fuelled by diesel or petrol
Post #449658 1st Sep 2017 1:50am
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Rolling with laughter Rolling with laughter Laughing Laughing
It is the British version of A/C - WA obviously doesn't have the requirement
Post #449671 1st Sep 2017 11:09am
knares
O,
when i was a young bloke living over there, I had a paraffin room heater in the back of my van but I would have thought the coolant heater would have by now been improved and been sufficient
Post #449683 1st Sep 2017 3:30pm
ohuntsman
With the earlier L322 models they're so you can get in a warm car in the morning before the engine starts, they came with a remote, although according to webasto modern diesels don't give off much heat for the heater matrix so they put them in for heat when the car is running.
https://www.webasto.com/int/markets-produc...y-heaters/
The irony of your comment tickled me! Thumbs Up
Post #449684 1st Sep 2017 4:03pm
knares
OK, thanks
Post #449686 1st Sep 2017 4:47pm
dolph34
Hi all , i have a fault on my FBH , circulation pump open circuit or short circuit to battery fault code 0x0034
Any thoughts please
Also paired a T21 remote with my FBH and all working fine. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #449695 1st Sep 2017 6:25pm
jonnyboy54321
Sounds like you need the pump i replaced as per the thread 2007 Vogue TDV8 with 255/55/20's fitted
Post #449711 1st Sep 2017 9:02pm
dolph34
Thank you i will get indie to have a look. Engine was out 6 months ago so i was hoping he forgot to connect something !!! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #449725 1st Sep 2017 10:34pm
standupking36
thank you kid sir for your efforts
Post #456604 8th Nov 2017 10:56pm
standupking36
well im new to all this tech stuff on these, so reading has prompted me to go try ours (didn't no i had such toys) so i've found said key fob, pressed the on button & just like magic i herd a fan kick in Very Happy so im now waiting to see if it works Cool i did notice the radio light start flashing, is that normal?
Post #456614 9th Nov 2017 12:00am
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
@johnyboy54321 - so is it still working? Still in the Mrs good books? Laughing
After a year of putting it off I had another play with this whilst I had the FF on the ramps doing the brakes.
I have noticed recently that when starting on a cold day the FBH fan comes on and runs for about 2 mins but feeling the exhaust it just stays cold so I don't think it is firing. I have never heard the fuel pump run so I pulled this off.
Checked I could draw diesel down the pipes from the tank so know they aren't blocked.
Hooked the pump up to a 12v supply and tested by touching terminals and the pump "pumped"
Checked the wire that goes to the pump with a voltmeter. Got a 11v reading both when the fan was running after starting the car, and also when I manually selected park heater from the MOST display (although this never triggers the fan like starting the car does.)
So I seem to have voltage to the pump but it is not "cycling".
I am going to try a reset using fuse 59 next as a double check. When I stripped the FBH the water pump was free and seemed OK although I didn't put 12v across to test as I din't know which terminals to use at the time but that might be my next step if I can summon the energy to strip it all down again!
Cheers, 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #465370 21st Jan 2018 1:25pm
Ianb4310
This thread is a great help 👍
Post #578047 1st Jan 2021 11:30pm
Since we’ve been having some very cold mornings, I decided to fire up the FBH a couple of times. Each time I try it, the fob goes green and I can hear it fire up but after a few minutes, it stops, having done no heating at all.
Does anyone have any clues where I might start to investigate?
Thanks Got - 2017 SDV8 Autobiography in Loire Blue
Post #578226 3rd Jan 2021 12:25pm
Dolphinboy
I would suspect it means your battery is not sufficient power to continue - the FBH is a big drain.
Post #578237 3rd Jan 2021 1:54pm
I did think of that as a possibly but the car was fully charged via my C-tek charger. Got - 2017 SDV8 Autobiography in Loire Blue
Post #578252 3rd Jan 2021 4:23pm
Page 3 of 4 <1234>
