![]() | Home > Technical (L322) > FBH - a Range Rover story |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
Apologies for the slow update. Dropped phone incident kinda messed up the pictorials so apologies at the quality of what follows!
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
Well done. |
Thanks John
Good work and good write up JB |
Hi Joe
Top man |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Well done JB, and thanks for taking the time to do a write up.
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Well done John - succes at last! I am surmising then, that the pump being u/s was stopping the FBH from doing anything else? Can you recall if you could hear your fuel pump running when it wasn't working?
The circulation pump not working would i believe prevent the fbh from firing (imagine it would proper boil the static water!).
Mightymarcos Member Since: 24 May 2015 Location: Alvechurch, near Birmingham Posts: 31 ![]() ![]() |
The water pump on my FBH has made a droning noise for nearly 2 years now. Is this a sign of impending failure or should I not worry? Taking a rest from Land Rovers for a bit....... |
EU 29 Member Since: 29 Oct 2014 Location: London Posts: 9 ![]() ![]() ![]() |
Really helpful info JB, thanks so much for taking the time to write this post. My 2007 VSE TDV8 FBH always worked on warmup mode with the engine running in the cold but never ever worked in my 3+ years of ownership for more than a minute when triggered with the remote.
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 784 ![]() ![]() ![]() |
Thanks for taking the time to write this up, I know nothing about modern vehicles and this article is beyond me but maybe one day.
EU29 - it won't ever run (other than the quick tests you did) if the circulating pump is u/s.
Thanks JB - I will keep a look out for one.
