Home > Maintenance & Mods (L322) > ... |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
25th Nov 2022 1:33pm |
25th Nov 2022 4:22pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
you'll get hot and cold bulb monitoring which causes flickering...this can be switched off with a diagnostic tool... ... - .- -.
25th Nov 2022 4:28pm |
25th Nov 2022 4:44pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7790 |
Yeah, as Stan suggests, the LCM checks bulb operation on startup and when running for bulb failures… as you know… that’s prob at least the initial flicker. I don’t know enough about the ballasts and stuff to know if that is supposed to sort it.
25th Nov 2022 5:49pm |
25th Nov 2022 6:32pm |
I don’t have ballasts on mine, don’t know what dictates whether the units need one. I know when I put LEDs in the side indicators they would only work one way round. Can’t remember what it said on the H7 LED replacements as they just worked first time. 2011 Range Rover Vogue SE 4.4 TDV8
25th Nov 2022 7:45pm |
25th Nov 2022 8:08pm |
26th Nov 2022 3:59pm |
26th Nov 2022 6:31pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
Whilst your low beams seem to be set at about the correct height, perhaps aiming the lights a little lower to get the fill-ins lower might not have much impact on the low beam cut-off.
26th Nov 2022 8:06pm |
26th Nov 2022 8:59pm |
Jcsh Member Since: 27 Jul 2011 Location: Poitiers Posts: 34 |
Could you please post a link for the HIDs that you recommend?
19th Dec 2022 10:17am |
19th Dec 2022 7:39pm |
