Home > Maintenance & Mods (L322) > ...
Page 1 of 4 1234>
Phoenix
Post #647731 8th Nov 2022 11:04pm
mjdronfield
they had halogens fitted so there was no warm up period and could be used to flash other drivers . I’d def not fit anything that has to warm up.
I’ve got LEDs in mine, they look much better and are a pretty good match visually. I also got some with LEDs all round to help avoid the directional issue.
I’d say they were better, but it’s not like having a bank of IPF spots like I had on my Classic.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #647733 8th Nov 2022 11:45pm
Phoenix
Post #647735 9th Nov 2022 12:14am
AJGalaxy2012
Re: HiD or LED?
Phoenix wrote:
I've looked at previous topics, as technology is always advancing, some of the previous options have been superseded.
I'm looking to replace the halogen high beam lamps as they're frankly pitiful.
HiD-wise, I'm considering the 6000 deg. K. / reflector version of these https://www.autobulbsdirect.co.uk/h7-hids4...n-kit.html
They're supposedly made for reflector type lamps but have the usual HiD warm-up time issue.
LED-wise, I'm considering https://www.amazon.co.uk/dp/B08N56JYJT/ More expensive, lower input power and slightly lower colour temperature (which gives a 'better' output but looks odd next to the factory HiD's) My main concern is the directional nature of LED's, which may give an odd beam pattern, although Philips probably have better product development than the average Chinese sweatshop.
I'm aware of the MoT implications and potential for false positives from the lighting control module lamp failure monitoring (sometimes called CANBus compatible etc.)
Any recent experience or alternative solutions?
Thanks.
Have you seen these:-
https://www.autobulbsdirect.co.uk/h8-h9-h1...HfEALw_wcB
I havent tried them but theyre on my shopping list. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #647738 9th Nov 2022 5:28am
GraemeS
Australia
I fitted 50W 4700K (almost same as the bi-xenons) HIDs with a pair of old large ballasts as I've had too many failed slimline ballasts. The lights point too close in front for the bright HIDs, presumably because the original lights are so poor compared with the bi-xenons that they need to be low. To correct the beam the tabs on my HID globes are bent slightly forwards to get the beam where it needs to be for country driving.
Flashing still flashes the bi-xenons and I'd rather not dazzle others with my HIDs which put the bi-xenons to shame once warm.
Post #647741 9th Nov 2022 7:42am
mjdronfield
These are the ones I fitted. Fairly cheap to try.
Maybe I needed different ones for more light output on the road…
https://www.ebay.co.uk/itm/371786510808
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #647747 9th Nov 2022 10:11am
mjdronfield
This was the discussion about upgrading that made me do it..
https://www.fullfatrr.com/forum/topic59406.html
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #647748 9th Nov 2022 10:20am
I’d advise LED having tried both in my old 322’s 👍
Post #647780 9th Nov 2022 6:53pm
JayGee
Just ordered these so will test against the existing H7. I thought the main beam was pretty good compared to any previous car I've had but you can never have too much.... 2012 TDV8 Vogue (L322)
Post #648230 16th Nov 2022 1:11pm
JayGee
Can't shift the covers to change them - feels like someone has glued them on. Is there knack like pressing and twisting ? 2012 TDV8 Vogue (L322)
Post #648442 18th Nov 2022 2:13pm
Stop asking the wife slave to do it sir… 😬
Post #648451 18th Nov 2022 3:11pm
JayGee
She's always asking me to take tight lids off jars so it's definitely one job I though I'd be up for..... 2012 TDV8 Vogue (L322)
Post #648455 18th Nov 2022 3:44pm
mjdronfield
Pretty sure they just turned, but may have never been undone before.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #648457 18th Nov 2022 3:52pm
JayGee
Plusgas and oil filter pliers 2012 TDV8 Vogue (L322)
Post #648460 18th Nov 2022 4:43pm
Phoenix
Post #648467 18th Nov 2022 6:17pm
Page 1 of 4 1234>
