Home > Technical (L322) > Ticking Noise when cold |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
I have a ticking/rattle noise only when cold, no error code or performance issue at all.
22nd Nov 2022 3:34am |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
Yep seems to be a common thing with the viscous fan gearing on the later L322s, mine does it sometimes.
22nd Nov 2022 10:09am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
If you disconnect the drive belt and the noise goes away you can then narrow it down to something the belt is driving, I.E. the fan or a pulley, not unusual for the idler pulley and tensioner pulley to be noisy on these |
22nd Nov 2022 1:30pm |
Can rule out pulley, tensioner and belt etc as they are all new. I also don’t think it is the viscos fan clutch as you can hear the fan seeding up without change in the ticking noise.. so there must be another explanation SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
22nd Nov 2022 8:17pm |
The other thing that can make this sort of noise is the high pressure fuel pump, its driven by the cam chain and located on the right hand side at the top of the engine as you look at it, if it is coming from that area, a fuel filter change can often help. |
23rd Nov 2022 12:25pm |
Interesting! can you elaborate a bit? also relevant to fuel filter?
23rd Nov 2022 9:48pm |
No chain problem that I know of but changing the fuel filter can help with the fuel flow to the pump, also its the cheapest place to start if you suspect the noise is coming from the pump. |
25th Nov 2022 10:04pm |
bradleypaulclarke Member Since: 09 Jan 2024 Location: Essex Posts: 2 |
Did you ever get to the cause of this, i have the exact same noise ive been stuggling to find anyone with the same issue |
9th Jan 2024 11:22pm |
