Home > Technical (L322) > Ticking Noise when cold
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
I have a ticking/rattle noise only when cold, no error code or performance issue at all.
https://youtube.com/shorts/1voxBTuDuLc?feature=share SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #648834 22nd Nov 2022 3:34am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Mine does the same and always has when start from cold i get a tick, tick, tick until it starts warming up. I read someplace it is to do with the fan? cannot hear it in the car just when outside. I always thought it was the FBH trying to fire up? 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #648839 22nd Nov 2022 7:50am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Yep seems to be a common thing with the viscous fan gearing on the later L322s, mine does it sometimes.
Even new viscous fans can do it as Sam in Motor and Machine explained the issue on his channel. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #648846 22nd Nov 2022 10:09am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
If you disconnect the drive belt and the noise goes away you can then narrow it down to something the belt is driving, I.E. the fan or a pulley, not unusual for the idler pulley and tensioner pulley to be noisy on these Thumbs Up
Post #648869 22nd Nov 2022 1:30pm
ffrr14
Can rule out pulley, tensioner and belt etc as they are all new. I also don’t think it is the viscos fan clutch as you can hear the fan seeding up without change in the ticking noise.. so there must be another explanation SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #648910 22nd Nov 2022 8:17pm
diesel Dave
The other thing that can make this sort of noise is the high pressure fuel pump, its driven by the cam chain and located on the right hand side at the top of the engine as you look at it, if it is coming from that area, a fuel filter change can often help.
Post #648947 23rd Nov 2022 12:25pm
ffrr14
Interesting! can you elaborate a bit? also relevant to fuel filter?
Are you suggesting the chain is oil starved? or has a slack? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #648987 23rd Nov 2022 9:48pm
diesel Dave
No chain problem that I know of but changing the fuel filter can help with the fuel flow to the pump, also its the cheapest place to start if you suspect the noise is coming from the pump.
Post #649164 25th Nov 2022 10:04pm
bradleypaulclarke
United Kingdom 2010 Range Rover SE 4.4 V8 Stornoway Grey
Tapping!!
Did you ever get to the cause of this, i have the exact same noise ive been stuggling to find anyone with the same issue
Post #682298 9th Jan 2024 11:22pm
