![]() | Home > Technical (L322) > Air suspension fault |
Bogi 6357 Member Since: 29 Jul 2019 Location: Scottish Borders Posts: 54 ![]() ![]() |
Little bit of an update
so tried a hard reset by disconnecting battery and touching bty pos cable and bty neg cable together , but no joy still registering OSF Wheel position way off , still sitting on bump stops Will try and reset with reader tomorrow and if not will investigate the outputs on the sensor wiring on osf Thanks for the assistance guys much appreciated , also I broke both clips on both sensor harnesses so need new clips to hold in permanently not sure if they can be ordered separately, got them off ok but new height sensors seem to be slightly different ,bottoming out before the clip would latch over the housing , ohh well all good fun 🤩 |
Another update 😂
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1233 ![]() ![]() ![]() |
If the same as mine, a 2006 Td6, behind the offside wheel arch liner, you will find the solenoid valve block that feeds air to both front airbags. Another point is, after mine has sat for months without being used, I often have some trouble when charging the battery and starting the car, the suspension will not operate properly, carry out the steering wheel lock to lock check a couple of times to reset the wheel angle sensors and this seems to help. Don't ask me why |
Thanks Merchy
Got to the bottom of it , was a leak in drivers side air bag
