![]() | Home > Technical (L322) > Air suspension fault |
RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 41 ![]() ![]() ![]() |
Hi,
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 515 ![]() ![]() |
Definately agree with RRYorks and as you suggest yourself, sounds like you've dislodged the connecting rod to the height sensor, or knocked off the wiring clip / damaged the wire - Easy enough to check if you have a look with the steering on full lock.
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Should that not be the OSF hieght sensor issue |
Not following you with that one Highroller? ![]() From this image posted by the OP, looks to me like the NSF height sensor is giving a reading that's literally 'off the scale':
Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Ah -- |
No worries, I see what you mean from the 2nd image! |
Bogi 6357 Member Since: 29 Jul 2019 Location: Scottish Borders Posts: 54 ![]() ![]() |
Lummox Member Since: 23 Apr 2022 Location: Doubtless Bay Posts: 10 ![]() ![]() ![]() |
Just a quick question about the height sensors.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
The bottom picture shows the top part of the sensor arm in the wrong position, just needs rotation to pount down instead of up, its caused when the suspension has been hanging.
Otoh I may be talking |
OK, so the rods arent broken. Have a wiggle of the connectors - that might help.
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
What should those voltage read Jon? |
The sensors receive a 5V supply voltage and their output varies with movement.
