Home > Technical (L322) > Air suspension fault |
Bogi 6357 Member Since: 28 Jul 2019 Location: Scottish Borders Posts: 54 |
Little bit of an update
9th Nov 2022 5:17pm |
Another update 😂
10th Nov 2022 9:37pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
If the same as mine, a 2006 Td6, behind the offside wheel arch liner, you will find the solenoid valve block that feeds air to both front airbags. Another point is, after mine has sat for months without being used, I often have some trouble when charging the battery and starting the car, the suspension will not operate properly, carry out the steering wheel lock to lock check a couple of times to reset the wheel angle sensors and this seems to help. Don't ask me why
10th Nov 2022 10:37pm |
Thanks Merchy
10th Nov 2022 11:13pm |
Got to the bottom of it , was a leak in drivers side air bag
20th Nov 2022 2:48pm |
