Home > Technical (L322) > Electrical issues /Parking sensors problem |
longd Member Since: 24 Oct 2020 Location: West Midlands Posts: 95 |
I am assuming there’s an issue with the driver side outter parking sensor… (mostly likely the wiring going to the sensor got pulled )
8th Nov 2022 4:53pm |
G3BML Member Since: 22 Jul 2021 Location: Glasgow Posts: 98 |
I bought my car with the parking sensors not working - front and rear. Turned out to be the rear bumper wiring loom. Was only £40 for a new loom from ducksworth |
8th Nov 2022 7:30pm |
Thanks for that info!
8th Nov 2022 7:38pm |
Double post |
8th Nov 2022 8:25pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3207 |
Likley just a cut wire where they go through the inner steel bumper (Common result after a nudge) so can be repaired without doing the whole loom. 2012 TDV8 Vogue (L322) |
9th Nov 2022 7:43am |
Thanks guys will pull the bumper off and check for continuity on the loom , pia. Lol |
9th Nov 2022 10:56am |
Pulled the bumper off and tested loom am getting continuity across all there sensor wires !
11th Nov 2022 8:05pm |
So I had a bit of time this evening and decided to remove the sheathing and tape on the loom … as you said broken wire !!! Obviously when I tested the wire it was bloody working !!! Lol |
15th Nov 2022 8:04pm |
Looks like this has happened before
15th Nov 2022 8:07pm |
The wiring on these cars is terrible quality. Bare unsheathed ends to connectors exposed to the elements and vulnerable to minor abrasions and impacts. They were never designed to last long..... 2012 TDV8 Vogue (L322) |
15th Nov 2022 8:08pm |
15th Nov 2022 8:50pm |
