Home > Technical (L322) > Electrical issues /Parking sensors problem
longd
Hey guys,
I’m having trouble with my parking sensors neither front or rear are working.
Upon starting the car and engaging reverse the parking sensor indicator in the car flashing and sounds but does nothing I’m not getting any clicking or vibrations front or rear.
They were working perfectly until qtr panel got clipped …
Since I’ve had the rear bumper off to paint it and refit there not working ?
I don’t have a fault code reader but I had a friend who cleared the logged faults and then sent me the faults that have returned after he cleared them - my mate is super busy so don’t want to peck his head anymore than I have already. Lol
Post #647682 8th Nov 2022 5:50pm
longd
I am assuming there’s an issue with the driver side outter parking sensor… (mostly likely the wiring going to the sensor got pulled )
Would would this on its own cause the entire pdc to stop working ?
Post #647683 8th Nov 2022 5:53pm
G3BML
Scotland 2010 Range Rover Vogue SE TDV8 Santorini Black
I bought my car with the parking sensors not working - front and rear. Turned out to be the rear bumper wiring loom. Was only £40 for a new loom from ducksworth
Post #647710 8th Nov 2022 8:30pm
longd
Thanks for that info!
So whole system shuts down over a faulty loom Bow down
No problem paying for a loom just don’t want to go down the route of replacing parts and not fixing the problem !!
Probably worth a punt for 40quid though
Post #647712 8th Nov 2022 8:38pm
G3BML
Double post
Post #647720 8th Nov 2022 9:25pm
JayGee
Likley just a cut wire where they go through the inner steel bumper (Common result after a nudge) so can be repaired without doing the whole loom. 2012 TDV8 Vogue (L322)
Post #647743 9th Nov 2022 8:43am
longd
Thanks guys will pull the bumper off and check for continuity on the loom , pia. Lol
Post #647751 9th Nov 2022 11:56am
longd
Pulled the bumper off and tested loom am getting continuity across all there sensor wires !
Really wish I had a fault code reader would just swap 3 and 4 over and check readings
Post #647916 11th Nov 2022 9:05pm
longd
So I had a bit of time this evening and decided to remove the sheathing and tape on the loom … as you said broken wire !!! Obviously when I tested the wire it was bloody working !!! Lol
Post #648185 15th Nov 2022 9:04pm
longd
Looks like this has happened before
Post #648186 15th Nov 2022 9:07pm
JayGee
The wiring on these cars is terrible quality. Bare unsheathed ends to connectors exposed to the elements and vulnerable to minor abrasions and impacts. They were never designed to last long..... 2012 TDV8 Vogue (L322)
Post #648188 15th Nov 2022 9:08pm
longd
Bow down
Thanks For the advise … I literally pulled the loom apart as what you said made sense …
Before I did that I tested for continuity and it tested perfectly… obviously I was bending the broken wires while testing and making it appear all good Rolling Eyes Rolling with laughter
All back together now and it’s working perfectly Thumbs Up
Post #648190 15th Nov 2022 9:50pm
