Home > Maintenance & Mods (L405) > A new little mod |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
2013MY... Has anyone tried this on a 13MY yet please? I only did it for swmbo’d as she can’t be doing with the faf of screens & buttons! |
25th Nov 2020 6:56pm |
Mark1107 Member Since: 19 Oct 2014 Location: Los Angeles Posts: 106 |
CTC,
26th Nov 2020 8:10am |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
I'll edit the first post with a note to say this won't work on MY2013. Kev
26th Nov 2020 9:33am |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Fitted mine today all good, just some tips for those doing this , the leather trim piece around the information display pulls directly towards you, the silver trim pieces at the side do the same. A firm pull is all that's needed. To remove the two top torx screws holding in the control panel I had to loosen the information display screen screws as the heater control panel screws caught the bottom of the info screen preventing them from coming out.
10th Dec 2020 1:40pm |
Glad it helped, dolph! Kev
10th Dec 2020 7:47pm |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 236 |
Did you ever figure this out Craig? I know it is a long shot. I think the only option for my 2013 is to get an aftermarket climate screen. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
6th Nov 2022 3:56pm |
Yes I’m afraid the only way I know is via an aftermarket screen sir… |
6th Nov 2022 5:48pm |
Thank you.
6th Nov 2022 7:06pm |
A used unit? From what car & model sir? |
6th Nov 2022 7:12pm |
2015 RR Sport (UK)
6th Nov 2022 7:36pm |
PLC Member Since: 23 May 2022 Location: Stafford Posts: 18 |
Will this upgrade work on a 2013 registerd car with an E 2014 MY in the vin, thanks in advance |
6th Nov 2022 8:48pm |
A sport one won’t fit a 405 sir I’m afraid… |
6th Nov 2022 9:20pm |
If your speedo clocks have blue outer rings and the car carries RANGE ROVER branding then no it won’t work sir… If your car has silver rings and caries the LR badge branding then yes it should work… 👍 |
6th Nov 2022 9:24pm |
PhillV8s Member Since: 03 Jun 2022 Location: Worcestershire Posts: 31 |
I have just done this upgrade. Gambled on cheap AC panel on eBay which didn’t show the part number but looked like a newer item. Gamble luckily paid off and when it was delivered found it was a GPLH unit. Fitted 10 minutes later and all good. My car is a 13 reg car but with silver dials and Land Rover l logo. 2013 SDV8 4.4 Vogue SE Aintree |
10th Mar 2023 4:09pm |
