Home > Maintenance & Mods (L405) > A new little mod
Page 3 of 3 <123
knwatkins
How odd. That's the same experience I had when I used a HPLA prefix part, which turned out to be due to the CAN speed.
What year is yours Craig? That part worked on my 2014. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #574091 25th Nov 2020 7:12pm
2013MY... Has anyone tried this on a 13MY yet please? I only did it for swmbo’d as she can’t be doing with the faf of screens & buttons!
Post #574099 25th Nov 2020 7:56pm
Mark1107
United States 2013 Range Rover HSE 5.0 V8 Fuji White
CTC,
Unfortunately none of the dials work on 2013 L405s. My wife’s old one, I tried a few different part numbers and our can bus is different. Most 2014s can handle the upgrade but not 13s... Big Cry
Mark
Post #574150 26th Nov 2020 9:10am
knwatkins
I'll edit the first post with a note to say this won't work on MY2013. Kev
Post #574157 26th Nov 2020 10:33am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Fitted mine today all good, just some tips for those doing this , the leather trim piece around the information display pulls directly towards you, the silver trim pieces at the side do the same. A firm pull is all that's needed. To remove the two top torx screws holding in the control panel I had to loosen the information display screen screws as the heater control panel screws caught the bottom of the info screen preventing them from coming out.
Great upgrade and very easy 👌
Many thanks to the original poster 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #575648 10th Dec 2020 2:40pm
knwatkins
Glad it helped, dolph! Kev
Post #575691 10th Dec 2020 8:47pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Cam-Tech-Craig wrote:
Mine turned up today and it doesn’t work!
I ordered a GPLA-18A802-DG and plugging it in does nothing! Only the hazard light switch illuminates, nothing else!
Did you ever figure this out Craig? I know it is a long shot. I think the only option for my 2013 is to get an aftermarket climate screen. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #647502 6th Nov 2022 4:56pm
Yes I’m afraid the only way I know is via an aftermarket screen sir…
Post #647521 6th Nov 2022 6:48pm
Bora20
Thank you.
I ordered a used unit from EBay UK to try for myself. If it doesn’t work, I will resell. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #647526 6th Nov 2022 8:06pm
A used unit? From what car & model sir?
Post #647527 6th Nov 2022 8:12pm
Bora20
2015 RR Sport (UK)
GLPH-18A802-DH is the part number. The seller recently replaced the main screen and climate pack with android units based on the other auctions.
If it doesn’t work, I can resell this and the capacitive screen head unit I have to purchase an android climate screen.
It is supposed to be -20C here later this week. My wife needs her heated seats button asap. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #647532 6th Nov 2022 8:36pm
PLC
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Will this upgrade work on a 2013 registerd car with an E 2014 MY in the vin, thanks in advance
Post #647537 6th Nov 2022 9:48pm
Bora20 wrote:
2015 RR Sport (UK)
A sport one won’t fit a 405 sir I’m afraid…
Post #647538 6th Nov 2022 10:20pm
If your speedo clocks have blue outer rings and the car carries RANGE ROVER branding then no it won’t work sir… If your car has silver rings and caries the LR badge branding then yes it should work… 👍
Post #647539 6th Nov 2022 10:24pm
PhillV8s
United Kingdom 2013 Range Rover Vogue SE SDV8 Aintree Green
I have just done this upgrade. Gambled on cheap AC panel on eBay which didn’t show the part number but looked like a newer item. Gamble luckily paid off and when it was delivered found it was a GPLH unit. Fitted 10 minutes later and all good. My car is a 13 reg car but with silver dials and Land Rover l logo. 2013 SDV8 4.4 Vogue SE Aintree
Post #659051 10th Mar 2023 5:09pm
Page 3 of 3 <123
