![]() | Home > Technical (L322) > 3.6 TDV8 Running Lumpy/Missing & Smoking |
Sounds like a fuel pressure problem, could well be the vanes in the HP fuel pump have corroded due to standing or the PCV / VCV is not moving, the EML can stay off until some meaningful torque is requested. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
Just an obvious one to give it a service, especially fuel filter.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
Had a look at this yesterday and upon starting it the EML was on.
P132E-22 seems to be a turbo actuator fault. Looking at the commander values versus the actual values it looks like both actuators are seized. This was 3000rpm:
This was at idle:
The car idles ok and feels smooth but is very smoky. When revving it you hear the noise change and it sounds like it’s missing almost but doesn’t feel like it and it smokes more. David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1810 ![]() ![]() |
Drop both the lower intercooler pipes
Thanks Mikey.
It's an actuator code. Most likely it's seized having been parked up, but if the turbo internals have collapsed, it also logs an actuator fault...
Thanks Mikey.
Managed to get this RR down to ours today to get a look at it.
I’ve taken the under trays off it tonight and popped the bottom pipes off the intercooler. There was some black oil that dribbled out of the pipes, not the intercooler. It wasn’t a lot though. How much would be considered normal on one of these? Looking under the bonnet, I’m glad mines an SC! There’s no room to move under this thing! David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior Last edited by dhallworth on 30th Oct 2022 2:22am. Edited 1 time in total |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2644 ![]() ![]() |
Check everywhere in the engine bay for chewed wires before getting too deep with the turbos. |
Definitely not much oil at all in the intercooler pipes.
Decided to have a look on the IID tool tonight just to see if one of the actuators was doing anything.
When the car is running it sounds lethargic when being revved as if no boost is being created. The smoke seems to have cleared as it’s not filling the workshop but it does smell rich. David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
deleted... |
The only fault code logged seems to refer to the passengers side turbo actuator but according to live values neither of them are moving. They’re both lingering around the same readings.
