Home > Technical (L322) > 3.6 TDV8 Running Lumpy/Missing & Smoking |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Sounds like a fuel pressure problem, could well be the vanes in the HP fuel pump have corroded due to standing or the PCV / VCV is not moving, the EML can stay off until some meaningful torque is requested. |
10th Sep 2022 1:56pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1462 |
Just an obvious one to give it a service, especially fuel filter.
10th Sep 2022 4:17pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3059 |
Had a look at this yesterday and upon starting it the EML was on.
11th Sep 2022 11:33am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1738 |
Drop both the lower intercooler pipes
11th Sep 2022 3:16pm |
Thanks Mikey.
11th Sep 2022 3:24pm |
It's an actuator code. Most likely it's seized having been parked up, but if the turbo internals have collapsed, it also logs an actuator fault...
11th Sep 2022 4:26pm |
Thanks Mikey.
11th Sep 2022 6:28pm |
Managed to get this RR down to ours today to get a look at it.
29th Oct 2022 10:31pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2457 |
Check everywhere in the engine bay for chewed wires before getting too deep with the turbos. |
29th Oct 2022 11:13pm |
29th Oct 2022 11:31pm |
Definitely not much oil at all in the intercooler pipes.
30th Oct 2022 4:58pm |
Decided to have a look on the IID tool tonight just to see if one of the actuators was doing anything.
30th Oct 2022 7:37pm |
deleted... |
30th Oct 2022 8:43pm |
The only fault code logged seems to refer to the passengers side turbo actuator but according to live values neither of them are moving. They’re both lingering around the same readings.
30th Oct 2022 9:10pm |
