Home > Technical (L322) > 3.6 TDV8 Running Lumpy/Missing & Smoking
Phoenix
That waveform is the classic 'unstick' routine for a jammed turbo actuator, the DTC will be set after the routine is completed and either the current is excessive or the commanded position is unreachable. The fuelling will be excessive as it doesn't have a fuelling map for low 0r no boost.
Post #646909 30th Oct 2022 10:16pm
dhallworth
The wave routine in the picture was peaking and troughing as the throttle was being blipped. If I held the revs stationary the commanded position went to a flat line as per the end of the graphs. It did the same but at a different position if I let it idle. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #646910 30th Oct 2022 10:24pm
Phoenix
Ah right - this is actual values not the ECM's interpretation. You can see the 'unstick' activity.
Green is the (processed from a PWM feedback signal) vane position and red is the actuator motor current this is during the shut down cycling of the vanes.
I'm not sure if your diagnostics can output the actual position vs. commanded position and actuator current.
Post #646912 30th Oct 2022 10:39pm
dhallworth
Interesting.
It’s the IID Bluetooth tool that I’m using. I’m not sure of it’s limitations.
The fault code on this car relates to the NS turbo, if that one was sticking would it stop the drivers side one operating correctly? Are they linked across the intake or are the independent of each other? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #646913 30th Oct 2022 10:43pm
Phoenix
Well there's two separate fresh and charge air paths but they both end up being shared across the plenum,
I think it's more a question of what the engine protection strategy is in the event of a stuck turbo actuator, most fail in the minimum position but there would need to be some protection if one jammed 'on boost', most likely it is detection of boost demand/actual correlation followed by commanded position not achieved, it would make sense to reduce activity on both turbos in either event.
Post #646916 30th Oct 2022 10:55pm
dhallworth
Thanks Phoenix,
I'll need to try and figure out how to get into the NS turbo I think. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #646972 31st Oct 2022 5:29pm
dhallworth
Been doing some reading tonight and have found these 2 threads which are a huge help:
Actuator Access - https://www.fullfatrr.com/forum/topic41533-15.html
Turbo Waste Gate - https://www.fullfatrr.com/forum/topic35415.html?highlight=turbo
Post #647009 31st Oct 2022 9:54pm
dhallworth
Pleased to report I managed to find the passengers side actuator. You need to look through this oval hole:
There’s 2 foil lined pipes that you need to peer behind and you can see the actuator.
I used a piece of welding rod that I’d bent to a hook and pulled and pushed the actuator after soaking it in penetrating oil.
After I’d moved it up and down a few times it seemed nice and free. I then got my Dad to sit in it and cycle the ignition a couple of times on and off and both actuators were moving nice and freely. I then fired up the IID tool and mapped the commanded position versus the actual position and started the car. The commanded and actual lines for both banks were all even and were moving in sync with each other.
The car sounded totally different and when giving it some revs you could hear it building boost. Sounds much better tonight Smile
Just a few other odds n sods to sort out and this car will be fighting fit again now.
Post #647093 1st Nov 2022 8:49pm
Phoenix
Excellent!
The next thing to do is make sure it gets a good, 'energetic' drive to work the actuators with a good bit of heat around to dry out any remaining corrosion and wear it smooth.
A lot of my 'special tools' are made from TiG rods or stainless steel brick ties...
Post #647101 1st Nov 2022 9:33pm
dhallworth
Thanks Phoenix.
Few jobs to do before we get to that stage unfortunately but I’m just glad that it’s running properly and making boost again now.
Will give it a good warm up and service too so there’s fresh oil going around the system. Is there anything worth doing to “help” a turbo get going again after it’s been parked up or are you as well just getting fresh oil into it and leaving it be?
Post #647104 1st Nov 2022 10:02pm
Phoenix
Fresh oil, heat and use are the best reconditioners for engines, I've seen a few rebuilt engines from various 'classic' (i.e. old and mostly unloved) cars rebuilt at great expense, then parked up and ignored for 11.5 months, then suddenly expected to perform like a daily workhorse, with predictable results.
It may be worth double-dosing with some fuel improver (Dipetane is my choice) to help clean up the engine or adding no more than 1.5 litres of Kerosene / AVTUR / Jet A-1 to a full tank of diesel to increase burn temperatures and burn off accumulated carbon in the cylinders and exhaust.
Post #647105 1st Nov 2022 10:26pm
