![]() | Home > Maintenance & Mods (L322) > Cracked side skirt after jacking incident… |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
So after a jacking incident last year my side skirt is cracked and has come away from the car.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
This may help.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
If there is room underneath with it in place, you could glue a strip of reinforcing plastic behind the side skirt. It would serve to hold the split parts together and also strengthen the joint.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
You can buy a plastic repair welder off Amazon for £24.99 that will do the job. Comes complete with all the clips and attachments |
I’ve got Overfinch side skirts… so add £££ to that price ![]() Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Cheers Weegie, FJ12Jagmen and Diesel Dave.
Quote...
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
I have a pair and one side has a small crack in... Which side is damaged on your car? |
Cheers Craig!
Ill have a look tomorrow and report back sir... |
So I finally got to a stage where I was able to refit my side skirts (I’ll post more on that later on another thread) so decided to give the plastic welder a go… and will say I am bloody impressed!
Not the prettiest of jobs but the repair is where you cannot see so not bothered by that. As you can see the pin melts into the plastic and when set it’s fairly strong. I’ve used plenty of clips on both side skirts and late last night I fit them back on the car. I paid £13 from eBay and am happy with that. Bargain ![]() Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Well, maybe it is a little noticeable… I forgot about my fix this side…
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 ![]() ![]() ![]() |
How about getting some satin black spray from Halfrauds after cleaning the crap off?. |
There’s a bit of road rash exposing the primer at the front and a few other wear and tear marks. I’ll probably get it resprayed and corrected as part of that at some point. Any decent body shop should be able to do something. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
