Home > Technical (L322) > TDV8 no power, white/blue smoke
Page 5 of 5 <12345
rar110
Thanks. 500 Euros is a great price, so I'd say refurbished.
As it's electrical I'd guess at battery voltage, something unplugged or an earthing point not connected or bad connection when re-assembling. ______________________________
Post #445216 20th Jul 2017 11:08pm
LASBAM
Germany 2007 Range Rover Vogue TDV8 Orkney Grey
Well after a long search it was a stuck LH turbo actuator. Bank B is the Left Hand Side seen from drivers view.
I tried very hard to get the turbo actuator running smooth again but with "WD40" its not really working..
Neutral
Anyone got an idea how to get it running smooth ? Any experiences made with this problem?
I really don't want to replace the LHD Turbo a second time.. This job is just horrible Big Cry
Post #448652 22nd Aug 2017 9:33am
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Probably soot in the vanes so need to be cleaned internally.Sure you will get some product that you can put through to loosen it up?
Good luck. 2012 TDV8 Vogue SE 4.4
Post #448706 22nd Aug 2017 1:56pm
rar110
A few questions.
Could the actuator be moved before installed? The Vanes and actuator shouldn't be sooted if fully reconditioned with a new CHRA or core.
Was the fan spinning freely before install?
The bearings should be lubed before starting for the first time.
Do you have a IID Tool? It would be good to read boost pressure for each bank.
There are a few possibilities.
1. I'm thinking it's unlikely that the vanes/actuator are stuck solid before install. But possible if supplier is not particularly ethical ie sent you junk.
2. The fan is not generating enough boost to result in the actuator to moving (ECU identifying insufficient boost) because fan is not spinning freely or out of balance (eg cheap knock off CHRA). Need to check boost pressure.
3. The actuator is not plugged in properly, defective or some problem accurately reading boost on that bank. Need to check boost pressure. I'm assuming it's a reconditioned unit and the electronic actuator was not replaced and is up to 10-11 years old. It's also possible but unlikely the turbo actuator needs calibrating like other electrics on the L322. Ive never heard of this though.
Good luck. ______________________________
Post #448763 22nd Aug 2017 8:57pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Neutral
are these the electronic type actuators ?
Post #448770 22nd Aug 2017 9:37pm
rar110
On the 3.6 tdv8 yes. Not sure about other models. ______________________________
Post #448775 22nd Aug 2017 10:13pm
LASBAM
-> yes of cours.
-> was done so this shouldn't be the problem. There was also filled Oil in the Oil access.
->Unfortunately not, but i have access to a Tester (Bosch KTS) so i can read it..
-> I hope not, but its always the same problem. My actuator rod get always gets stuck in open position and doesn't move back again and i have to free it again. Then the car starts and run smooth till i got it's temperature.... Arrow "Kloing Kloing" and the game starts again..
-> To be honest i don't understand this question. But the car got enough power and runs very good. I will check Boost Pressure asap. The Actuator is not running very smooth, very rough especially when the car gets warm. I will try to free it with some Teflon Spray the next days and will tell you what happens..
-> The Turbo Actuator is not needed to be calibrated due to my LR Service. -> I think the best is to read the turbo pressure. You think my MAP sensor could be faulty as well?
Thank you much ahead Smile
Post #448840 23rd Aug 2017 4:41pm
bembo449
ive just replaced one on a customers Mercedes , transformed the cars performance but the car did not smoke at all with a faulty actuator just under powered
Post #448886 23rd Aug 2017 8:56pm
Croker
Spain
LASBAM wrote:
The price was 500,- Euros per each.
As i said the work is nearly done i was a bit too quick..
Now we have the Problem of 2 trouble codes.The Turbo actuators are working -> checked with Camera...
P132E "Turbo boost control B performance"
P138F "Turbo boost control unit Sensor minimum"
Anyone got an idea?
Did you work out why you got the P132E fault code after replacing the new turbos? I have the same issue and cannot work out the solution... TDV8 3.6 2007 Vogue SE
Porsche Boxster 3.2S 2000
Porsche 928S 1986.5 Manual
Fiat Dino 2000 Coupe
BMW 2002 tii 1974
Mercedes 450SL 1973
Mercedes SL500 1995
Honda Civic 1.8 Si 2006
Fantic Caballero 125 Scrambler Deluxe
Post #620256 16th Jan 2022 10:47pm
LASBAM
Hi,
yes actually the control arm was stuck and tightened too strong by the company who refurbished the turbos..
I built myself a nice tool which i could attach directly to the control arm and move it free.. Did this movement 100times and went afterwards directly straight to the Autobahn. Since that i never had the same issues again Very Happy Current:
- 2006 RR L322 - 3.6 TDV8
- 2022 MB AMG GT BS
- 2020 Audi Q2
Past:
- Ferrari California 30
- 2018 Abarth 595 Competizione
- 2009 Porsche Cayenne Diesel
- 2010 MB E500 Coupé
- 2005 Porsche 996 Turbo
- 2002 Porsche Boxster 986 S
- 2001 Audi S8
Post #646322 23rd Oct 2022 4:51pm
Page 5 of 5 <12345
