![]() | Home > Technical (L322) > TDV8 no power, white/blue smoke |
LASBAM Member Since: 04 Apr 2017 Location: Reutlingen Posts: 26 ![]() ![]() ![]() |
Well after a long search it was a stuck LH turbo actuator. Bank B is the Left Hand Side seen from drivers view.
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Probably soot in the vanes so need to be cleaned internally.Sure you will get some product that you can put through to loosen it up?
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
A few questions.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
are these the electronic type actuators ? |
On the 3.6 tdv8 yes. Not sure about other models. ______________________________
Was the fan spinning freely before install?
ive just replaced one on a customers Mercedes , transformed the cars performance but the car did not smoke at all with a faulty actuator just under powered |
Croker Member Since: 23 Mar 2021 Location: Granada Posts: 33 ![]() ![]() |
Did you work out why you got the P132E fault code after replacing the new turbos? I have the same issue and cannot work out the solution... TDV8 3.6 2007 Vogue SE Porsche Boxster 3.2S 2000 Porsche 928S 1986.5 Manual Fiat Dino 2000 Coupe BMW 2002 tii 1974 Mercedes 450SL 1973 Mercedes SL500 1995 Honda Civic 1.8 Si 2006 Fantic Caballero 125 Scrambler Deluxe |
Hi,
